JMB RetrofitsChris Nott
Results 1 to 10 of 10
    Jan 2006
    Deal, Kent
    468
    Front pad changing - how to...
    Hi Guys,
    Need to bail a mate out and change his front pads tonight before they go metal to metal!
    Do the calipers swing up out of the way to change the pads, or do they have to come off completely to get at the pads on an A4?
    I didn't do mine myself when I had it.
    It's an N plate / 96 1.8 NA.
    Jun 2003
    World of my own
    9,813
    You'll have to wind back the piston to get new pads on so I think they have to come off completely. It's only 2 bolts, but they'll be very tight.
    johnyj's Avatar
    Jun 2004
    253
    the rear pads you have to wind back the front just take the caliper off and push the piston back in just watch the resevoir
    Turbo Lag FTW's Avatar
    Hate those none insured you know who types
    Feb 2007
    Carlisle, Cumbria. Not Geordie nor Scotch!
    233
    They come off completely, the two bolts u need to remove are covered with rubber cover. I had to use a Hex 45 I think, as a 6 or 8mm allan key wouldnt do the job, knowing the awkwardness of car companies it could be a 7mm key. Once its off make sure the piston is back, place in the new pads and put back on over the discs and replace bolts.
    Also get the right pads for the car, I know from experience as some eijit from Hi-Q fitted the wrong discs with the right pads on the car when my mother owned it . There are different types available, ie the size of the discs/pads. A hint: There is a 3 letter code on the sticker for the car in the service manual. One code corresponds to the brakes.
    Audi A4 1.8T Sport
    Jun 2003
    World of my own
    9,813
    Quote Originally Posted by johnyj
    Didn't know that, thanks, I've only done the rears on mine.
    If you buy them from GSF they'll know the right ones.
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    Front Brakes:
    Tools: 7mm Hex Key, Needle-nose or similar pliers. 17mm socket and wrench for lug nuts. Torque wrench recommended. Possible need for C-Clamp or large pair of pliers (for pushing piston back on front calipers).
    Put car in gear and engage emergency brake.
    Remove plastic caps over lug nuts using Audi's U-shaped plastic tool (see tool kit or glove box).
    Loosen lug nuts.
    Jack up front wheel (see jacking points in owner's manual). I used a small floor jack instead of Audi's jack.
    Remove lug nuts and remove wheel. (Recommend using jack stand under car somewhere, but you don't have to get under the car).
    On the back side of the caliper, near top and bottom, you will find 2 black plastic plugs, about 1/2" diameter. Pull these out by hand. Behind these plugs are the hex bolts.
    There is a wire "spring" on the outside of the caliper. Pull it off with pliers. It has a few pounds of tension behind it, but isn't that bad to remove or re-install (can actually be done by hand).
    Remove the two hex bolts with the 7mm hex key or equivalent. (I think 7mm was the size). Mine weren't on all that tight and they were easy to get out.
    Now the main part of the caliper is loose. Pull it straight back. It will still be attached by the brake hoses (and ABS wire?). Lay the assembly down on top of the nearest suspension member, so it isn't hanging by the hoses.
    Remove the back pad. It just pulls out. It has a neat 3-prong clip that holds it to the inside of the caliper piston. Remove the front pad. On mine, it was essentially glued to the caliper, so some force, or a screwdriver might be required. I think the "glue" was applied by Audi to absorb vibration and reduce squealing.
    Take note if there are any arrows, etc. on your new pads indicating which side is up (same as which way the tire rotates going forward). The original Audi front pads have these. My Ferodos and the Audi rear pads didn't.
    Install 2 new pads in the same way as the old ones came out. You'll have to decide what to do about the "glue" situation. There was enough left on my calipers that the new pads stuck to it pretty well. Or, there are commercial rubberized coatings (liquid or spray) that you can apply to the backs of the pads to reduce the tendency to squeal. I used one of these when I reinstalled the original pads.
    Try to fit the caliper back into position over the rotor. If the pads you are replacing have nearly all of their original thickness remaining, it might fit. If not, you will need to push the piston back into the caliper enough to make it fit. I didn't have to do this (in front). It is probably too hard to do by hand. In the past (other cars), I have used a C-clamp fit over the piston and the back of the caliper to push it back. (Protect the piston face with a scrap piece of wood). Or, a large pair of pliers would work similarly. Note that as you push the piston back, the level of fluid in your master cylinder reservoir will rise. You might have to remove some. (A clean turkey baster works well as a siphon for this).
    Reinsert the 2 hex bolts and tighten. (Try to get it about like it was, somewhere between falling apart by itself and breaking something. I don't have the torque spec.) Reinstall rubber plugs.
    Reinsert the spring on the front with pliers.
    Clean up/wash/wax wheel, front and back, if you have the time or inclination.
    Put wheel back on, snugging up lug nuts (not final tightening) while wheel is still in air.
    Lower car. Use torque wrench to tighten lug nuts. 80 foot-pounds is the Audi spec for my 2.8 wheels. Push plastic lug nut covers back onto nuts.
    Repeat with other side.
    Note: Your new front pads might come with a wire and connector hanging from them. This is a wear sensor used on some models, but not the A4. Just cut it off close to the pad.
    Jul 2007
    Leicester
    456
    Thanks Doc, ive saved that very handy guide im sure it will come in use when my new ECS big brake kit arrives! ill be replacing stock calipers with porsche boxster calipers with new discs + pads.
    thanks again!
    p.s. those hoses are on there way!
    Biglockie's Avatar
    Aye you know it makes sense
    Nov 2006
    cumbria
    1,030
    http://forums.vwvortex.com/zerothread?id=2218737
    check it out includes pictures to back up Docs post
    johnyj's Avatar
    Jun 2004
    253
    dappa where are you sourcin the carriers from??
    Jul 2007
    Leicester
    456
    ive ordered this kit here from ecs tuning its the stage 2v2
    http://www.ecstuning.com/stage/edpd/...%20Stage%202v2
    there is a cheaper option, if you can source a decent set of 2nd hand porsche boxster calipers you can buy the calipers carriers here: http://www.purems.com/products/product.php/II=1310
    i was too lazy doing it that way.
