AH FabricationsChris Nott
Results 1 to 8 of 8
Thread: maffy fcuk
    johnyj's Avatar
    Jun 2004
    253
    Red face maffy fcuk
    bought a maf for Ł70 replaced it and driveability is alot smoother but i still have the revs dipping after if settles back down after reving
    any other ideas
    i thought it might be an air leak?
    johnyj's Avatar
    Jun 2004
    253
    thanks for the response i have noticed that when the car is cold it hardly does it
    would this be a temp sensor thingy?
    any ideas plz....
    Jun 2003
    World of my own
    9,813
    Temp sensor is a common fault and can throw all sorts of wierd behaviour. £20 from a dealer and an easy fit so I'd change it anyway.
    johnyj's Avatar
    Jun 2004
    253
    thanx where abouts is it
    i had the temp gauge sensor changed is that the same thing?
    Jun 2003
    World of my own
    9,813
    Same thing, so not that then.
    icenutter's Avatar
    Jun 2006
    595
    Do you have vag-com? You can use it to get readings of things like expected and actual MAP.
    Jul 2007
    85
    idle contol valve? or could be the throttle control unit
    2001 Ming blue s3 with silver/black alcantara seats.
    2002 silverstone blue m5
    Wanted---- k04 turbo!!
    johnyj's Avatar
    Jun 2004
    253
    have got vag.com but waitin for cable to arive
    where abouts are the contol valve and throttle unit?
    thanks
