AH FabricationsSky Insurance
Results 1 to 7 of 7
Thread: FK Halos
    May 2003
    Oxford, UK
    85
    Question FK Halos
    Just bought a set of the black FK Halo headlights, got them fitted but the level adjusters no longer work. Am I missing something, there are no instructions to speak of? Other than that they are quality...
    2000 Black A4 Avant 1.8T Quattro Sport 221bhp
    AmD Viper DV, remap, Milltek exhaust, 18" alloys, RS4 Mirrors, Grille and Spoiler
    Uprated speakers, CD changer and Rockford Fosgate amp/12" sub
    Randomjim's Avatar
    Aug 2006
    Sussex, Uk
    2,747
    You need to take the unit off your old headlights. I didn't bother with mine.
    Built in Germany, Perfected in England
    May 2003
    Oxford, UK
    85
    Is that easy?
    turboaudi's Avatar
    Nov 2006
    North Yorkshire
    57
    piece of cake mate. i did them with mine ,you just twist and pull out the false ones on the new units and fit the others just make sure you get them the right way so they go up or down
    billybravo's Avatar
    MODERATOR
    Feb 2005
    stockport england
    1,044
    can i ask where you got these from and how much cheers
    TopGear Stockport / Longlife Exhausts /
    www.TopGearStockport.co.uk
    Baker21's Avatar
    OEM+ A4 Avant
    Mar 2007
    Northants
    74
    Probably a little late but you will need to remove the 'fixed pivot' off the FK units and replace it with the 'levelling motor' from your OEM headlamps.
    This is common on any aftermarket headlamps that you purchase.
    Best regards,
    Baker21 - 'OEM+' AUDI A4 AVANT 2.6 V6
    May 2003
    Oxford, UK
    85
    I will have to remove the FK's again anyway so this isn't a problem, I basically didn't look at the old ones to know the motor was inside the oem lamps, I assumed it was outside the unit - you know what the say about assumption!! One of them is faulty anyhow so they have to come out again - the right side light reflector points at the ground as it's not attached to one of the beam adjusters.... Got them off EBay by the way, there are a few on there.
