Sky InsuranceVolks Autos
Results 1 to 10 of 10
    Jul 2007
    85
    thermostat location?
    hi guys im looking to locate the thermostat on my 1.8T 95. as i need to test it as my car kept overheating yesterday but i have no signs of the head gasket going. cheers
    2001 Ming blue s3 with silver/black alcantara seats.
    2002 silverstone blue m5
    Wanted---- k04 turbo!!
    Jul 2007
    85
    anyone?
    Beerzo's Avatar
    Masa'warty 3200... Talk To Me!
    Feb 2006
    Scotland
    1,241
    I will have a look through my Haynes manual tonight and give you a shout.
    Biglockie's Avatar
    Aye you know it makes sense
    Nov 2006
    cumbria
    1,030
    I think its on the water pump at the front of the engine, on the right hand side as your in front of the car.
    Jul 2007
    85
    thanks guys if you could have a gander in the manual too id appreciate it!
    Jul 2007
    85
    if anyone could help id appreciate it as i need the car for work tommorow, thanks!
    joost's Avatar
    Nov 2005
    Lancs
    1,166
    The thermostat housing is on the underside of the water pump housing (right hand side of the engine as you look from the front). It's easiest to get to from underneath but unfortunately thet means you've probably got to remove the undertray.
    Justin
    2001 VW Golf 2.3 V5 (170) Highline, Indigo Blue - standard, for now...
    A4 (B5) SE with a few slight amendments here and there (sold)
    Jul 2007
    85
    thank you so much mate ill be up bright and early to change it then, what does the housing look like amte? pipes going to it? thanks again!
    macca's Avatar
    Sep 2006
    Sussex.
    525
    usually, if it's the same as my '98 1.8T, underneath black plastic elbow on water pump, with pipe then going up into engine bay area somewhere, becareful if yours is the same as the plastic on mine, it can be a bit brittle and break. if memory serves me right, then 2 or 3 10mm bolts.
    thermostats are cheap and to be honest if you are draining coolant etc to get to it i would just put a new one in instead of testing old one, could save time and money later.
    1998 A4 1.8T Sport - For Saturdays
    2003 VW Golf MKIV R32 - For Sundays
    2000 Peugeot 406 HDi - For when it's raining
    1996 Kawasaki ZX7R - For when I'm late for work!
    Mods- Forge Dump Valve, The Engine Shop Power Plus based Engine (Low Comp. Forged pistons, Arrow H-Section Rods, Newman fast road cams, polished & ported head), 19" wheels, B&M Short Shifter, Greddy Turbo Timer, RS4 Grill, Weitec GTN coilovers, HKS modified air filter, Autobahn88 FMIC, ChippedUK custom map. Some Turbo mods ongoing.
    Jul 2007
    85
    cheers guys im gonna change it now
