EM TuningAH Fabrications
Results 1 to 11 of 11
Thread: just wondering
    turboaudi's Avatar
    Nov 2006
    North Yorkshire
    57
    just wondering
    i am going to take the throttle housing off the car to spray some carb cleaner in to it and give it a good clean out. would i have to get it recalibrated afterwards or could i just bang it straight back on after i clean it. thanks in advance chaps
    billybravo's Avatar
    MODERATOR
    Feb 2005
    stockport england
    1,044
    after your done put your key in and turn the power on but dont start the engine or the throttle then the ecu should calilbrate it for you.
    it takes about 30secs
    TopGear Stockport / Longlife Exhausts /
    www.TopGearStockport.co.uk
    johnyj's Avatar
    Jun 2004
    253
    think u need to take the bat lead off first
    billybravo's Avatar
    MODERATOR
    Feb 2005
    stockport england
    1,044
    no you dont
    a4quat's Avatar
    Aug 2006
    middlesbrough
    366
    i think there is also a gasket to buy first aswell, thats what i got told any way!
    03' S4
    00' A4 1.8TQS (sold)
    Seat Ibiza GTI (track day car) (sold)
    Seat Leon (her car)
    DRZ 400S
    jcb
    Sep 2005
    uk
    4,077
    Talking
    Quote Originally Posted by turboaudi
    jsut do it with the engine running, cleans a few other things out too!!
    shineydave's Avatar
    Jan 2006
    Bradford, Yorkshire, UK
    912
    if you do it using the key method it resets the valve to the learned positions which don't take into account any wear / movement in the body or flap. if you take the battery off all the learned values are erased and then it'll do a full callibration. under normal circumstances the key method will be fine but if you think something has got disturbed then the battery method is going to give better results
    Dave
    "If that's the Turbo Fairy knocking tell Her I'm not in"
    johnyj's Avatar
    Jun 2004
    253
    roger bravo
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    Or if you have vagcom you can get it to calibrate through that.
    Jul 2007
    17
    when you put it back on, the car will do it automatically.
    turboaudi's Avatar
    Nov 2006
    North Yorkshire
    57
    thanks for all advice ,
    this is why most audi owners think this site is the dogs ********, you always get helped out
