Results 1 to 11 of 11
    Jul 2007
    17
    Question MAF sensor adapter???
    I'm putting together my own intake for my 98 a4 1.8 and am wondering if i will need an MAF sensor adapter for it when i put the new intake on. Also on the stock airbox their seems to be alot of sensors and wires going into the airbox and coming out of it, what will i need to do with thos becuase i'm not sure what to do with them with the new intake. The old airbox will be taken out .
    shineydave's Avatar
    Jan 2006
    Bradford, Yorkshire, UK
    912
    not wanting to sound condescending but if you have no idea what the sensors do how do you think you can put something together that'll be better than the standard intake that Audi spent a considerable budget on developing
    might be worth doing some research on the various functions of these sensors before messing around
    Dave
    "If that's the Turbo Fairy knocking tell Her I'm not in"
    Danielson's Avatar
    Jun 2004
    UK
    704
    this might help ya, hit me up with a pm if you have any more Q's....
    jimya4t's Avatar
    Sep 2006
    newcastle
    73
    Hi snoop, where did you get the u bend pipe from and any idea where i can get some of that heat shield from just my standard airbox is knackered.
    Jul 2007
    Leicester
    456
    hi mate, is that the carbonio air set up?
    would you highly recomend it?
    thanks.
    Danielson's Avatar
    Jun 2004
    UK
    704
    Quote Originally Posted by jimya4t
    i had the pipe made at powerflow, who make custom exhausts. they are very handy chaps indeed. =) as for the heatshield i got that from work, its used on the elise to stop the rear clamshell from melting as the silencer sits right below and as you know exhausts get quite hot. =)
    i actually just got another one to remake mine as its started to crack from all that heat from my little K03, it lasted a good 4yrs. im sure you could go to the scrapyard and find something very simular.
    Danielson's Avatar
    Jun 2004
    UK
    704
    Quote Originally Posted by dappadan786
    thanks.
    nope, its a bmc carbon dynamic airbox. to be honest its a lot of money, but it does sound the tits and MAYBE pulls a little harder up top.
    Jul 2007
    Leicester
    456
    Quote Originally Posted by snoop
    sweet! looks like BMC is on the shopping list. i was going to go for the carbonio kit which is alot more than the BMC!
    thanks mate.
    jimya4t's Avatar
    Sep 2006
    newcastle
    73
    cheers snoop a just work around the corner from powerflow al pop in tomorrow.
    Dec 2004
    Lancs, uk
    263
    Ensure you use the complete MAF body, or if you just use the sensor, a similar flowing tube/housing, or the MAF flow/temp readings will be off.
    jimya4t's Avatar
    Sep 2006
    newcastle
    73
    chears, got it
