Sky InsuranceVolks Autos
Results 1 to 9 of 9
Thread: tec help needed
    turboaudi's Avatar
    Nov 2006
    North Yorkshire
    57
    tec help needed
    ive fitted a new clutch and i am getting a bit of judder when letting out the clutch when i set off, also it seems to snatch a bit some times.. just wondering if any one had any ideas why. it didnt do it with the old clutch. thanks for any of your help. oh its a 1.8 t sport b5 96
    Biglockie's Avatar
    Aye you know it makes sense
    Nov 2006
    cumbria
    1,030
    How many miles ago did you fit it?
    turboaudi's Avatar
    Nov 2006
    North Yorkshire
    57
    its done about 40-50 miles with the new clutch in
    Randomjim's Avatar
    Aug 2006
    Sussex, Uk
    2,747
    Did you change the fly wheel?
    Built in Germany, Perfected in England
    turboaudi's Avatar
    Nov 2006
    North Yorkshire
    57
    no it was a clutch kit with clutch and pressure plate and release bearing. it didnt judder before
    Randomjim's Avatar
    Aug 2006
    Sussex, Uk
    2,747
    It's a dual mass flywheel i think you have to change both.
    Jun 2007
    Hi,
    I am new to the forum and have just read this post. I had a new clutch fitted to my 98 B5 1.8 T sport avant just over a year ago, the flywheel was also replaced due to excess movement. I did have a small amount of judder until everything had bedded in, for a couple of hundred miles. I was told this was to be expected and to be gentle with it.
    Hope this helps
    Mike
    jcb
    Sep 2005
    uk
    4,070
    really? flywheel shouldn't need changing unless damaged or faulty. was the surface OK?
    May need a bit of time to bed in, give it some welly and see how you get on
    Randomjim's Avatar
    Aug 2006
    Sussex, Uk
    2,747
    I phone my local supllier at work the other day for a price on mine and he said both have to be changed at the same time. i asked a few people and they all said the same thing.
