Chris NottMonster Motorsport
    Jul 2003
    Birmingham, England
    21
    Occasional grinding when turning right..
    Hi,
    As the title suggests occasionally when I'm going round an island or a right hand bend (doesn't happen on a turn into a road normally - tight turn) I hear and feel a grinding which I think is from the front passenger side wheel. It tends to be worse on an island when there is more g force on the car.
    The only related incident which I think may have caused this is I hit a pothole doing about 35mph a few weeks back. Nothing occured till now however.
    Anyone any ideas?
    BTW Car is a 1995 A4 TDi Saloon.
    Gareth
    Feb 2003
    Lincolnshire/Bournemouth
    739
    Re: Occasional grinding when turning right..
    Could be as simple as a bent brake dust shield. More likely to be a ball or CV joint.
    Anito's Avatar
    Dec 2003
    Chester
    429
    CV Joint would be my guess. I used to ahve a coupe which started doing it. After about 120K miles both wheels were doing it and I had to change both CV joints.
    Aug 2003
    Kingston, Surrey
    95
    The EXACT same thing happened to me a few days ago in my A6 - hit a pothole, and then a day later suffered from a grinding noise when turning right.
    Took it into Wimbledon Audi, and they've diagnosed a bent left track rod arm, and another part connected with the steering rack. However they couldn't get the small part on its own so they've gone and replaced the entire steering rack, bushes, the works
    Luckily it's under warranty!! U'd better get it looked at chap - as Mark/excursion says, it could be the brake shield, but it could and most probably is something a little more serious.
    Good luck!
    Tone
    Jul 2003
    Birmingham, England
    21
    Well it's booked in for Sat now. The steering itself seems exactly the same as it was before car met pothole - there's no pulling to one side or anything, there's no vibration or movement through the steering wheel to suggest perhaps a warped brake disc and it stops in a straight line if you let go of the wheel under braking. So I'd imagine/hope it's the CV joint or as suggested a bent brake disc cover.
    I'll soon know. [img]/ubbthreads/images/graemlins/frown.gif[/img]
    Jul 2003
    Birmingham, England
    21
    Have taken the car in.. theres nothing wrong with the suspension etc.. my Mechanic has decided it'll be one of the CV joints.
    I'll be getting that fixed pretty soon. Gotta find the cash first, though he says it isn't urgent as Audi over engineer parts anyway it'll last quite a while. Besides when it gets worse he'll be able to figure out which one is knackered easier.
