Volks AutosEM Tuning
Results 1 to 7 of 7
    Jun 2007
    145
    how do you change the interior door lock pins? the bits that stick up when you unlock
    as it says above, do they just pull off or unscrew or do i need to take the door panel off?
    Jun 2007
    145
    just in case i did not make it clear its the black bits that stick up when you unlock the car
    mjc23's Avatar
    Nov 2006
    Somerset
    35
    They screw off, but you'll need to grip it quite hard. And then they just slide off at the end. Not too tricky really. Hope that helps.
    Danielson's Avatar
    Jun 2004
    UK
    704
    you dont need to take the door pin off to remove the panel. just remove all the screws and lift the panel over the pin.
    Jun 2007
    145
    Quote Originally Posted by mjc23
    so they screw off. I was not sure as the ally ones i got from vag com look like they just push on, there is no thread in them.
    was just worried about buggering anything up on the stem that they go on.
    Jun 2007
    145
    Quote Originally Posted by snoop
    ually wondered if i needed to take the door panel off to get the door pins off but it would seem i dont
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    Quote Originally Posted by jazzyc
    as they are made of ally they might just be able to twist them on and it should self thread them inside?
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
