Badger5Monster Motorsport
Results 1 to 7 of 7
    Oct 2005
    lebanon
    92
    Smile Torque setting wanted for the oil pressure switch
    as the title , could some body help me with the torque setings for the oil pressure switch? i dont know how many NM i should tight it , and also for the oil cooler bolt how much i should tight it.. engine is v6 12v , please any help would be appreciated!
    Biglockie's Avatar
    Aye you know it makes sense
    Nov 2006
    cumbria
    1,030
    Till it stop leaking fella, thats the best setting
    Oct 2005
    lebanon
    92
    well i found in one site , that for the oil cooler 30 NM , according to mitchell on demand , but in audi manuals they didnt specified any torque settings , neithers for the oil switch.
    Biglockie's Avatar
    Nov 2006
    cumbria
    1,030
    Ths switch is on an NTP style thread i fitteed mine into an manifold to allo me to take a statci pressure line from it, and i just nipped it up till it was tight ran it and checked for leaks.
    Oct 2005
    lebanon
    92
    do u have some specifications about changing it? i barely saw it , even i didnt see it i feelt it with one finger its under the ac compressor upward to the oil cooler , so any advices how to take it out in the best way what i must remove what i must do?
    cheers my friend
    Biglockie's Avatar
    Nov 2006
    cumbria
    1,030
    There are two switches there the one you need to remove has to be done with a 22mm spanner the other is slightly smaller and is just above the oil cooler, if you remove the expansion bottle you'll be able to see it properly
    http://www.clubb5.com/information/oilguage.shtml
    check this out dude^^^^^^^^^^^^^^^^^^^
    Oct 2005
    lebanon
    92
    my friend , my car is v6 12 valve not a 1.8 T
