JMB RetrofitsBadger5
Results 1 to 18 of 18
    Jun 2007
    145
    air bag warning light - help needed
    I have a warning on my dash saying air bag.
    Tge i bought the car from had the light reset and indeed when i left them it was off. I have now however noticed that it is back on.
    any ideas as to the cause and how i fix it.
    its a 2000 facelift 1.8 t sport.
    thankyou
    Danielson's Avatar
    Jun 2004
    UK
    704
    its more thatn likely the airbag in one of the seats. a common fault. use the search function buddy.
    Jun 2007
    145
    that might tie in then as when i picked the car up the seat back was off the drivers seat and they said they couldn't get it back on. i have put it back on now but maybe thats why it was off?
    Jun 2007
    145
    ok, so i am pretty sure the fault must lie with the drivers seat airbag. I have ran a search on here and it seems that there are wires under the seat that are often a problem.
    which ones are they and can i saftley take them apart and clean up the connection without setting things off??
    205man's Avatar
    May 2006
    worcestershire, uk
    1,016
    also check the connector under the seat its quite common for these to play up, the sort of get corroded, and can set the light off, some people remove the connector and hardwire the seat.
    my light came on once when i adjusted the height of the passenger seat, and didnt relase the was something under the seat and it pulled on the connection
    205man's Avatar
    May 2006
    worcestershire, uk
    1,016
    before playing with any airbag disconnect the battery and dont touch airbag/connections for at least half and hour, to allow them to discharge first, or you may get a nasty surprise
    Jun 2007
    145
    so just to be sure then, dissconect the battery and leave it for 30mins or so,
    is this going to mess up anything else on the car i.e alarm etc? the car is standard apart from different stero but that dosent have a code.
    once i have looked at the wires and connectors i guess i wont know if its sorted untill i can get the light reset?
    Jun 2003
    World of my own
    9,813
    You don't actually need to disconnect the battery, just don't fiddle with anything airbag related with the ignition on.
    Lowlife's Avatar
    German Hardcore
    Jan 2007
    Herts
    566
    Quote Originally Posted by jazzyc
    Should be fine, I'd disconnect the battery, working on any live electrics is unbelievably stupid, let alone ones that are wired to explosives...
    Jun 2003
    World of my own
    9,813
    Yeah the clue is in the fact they're only live with the ignition on.
    Jun 2007
    145
    so as long as i dont have the keys in the ignition all will be ok?
    my only concern about disconecting the battery is i might loose any settings the car has learnt etc?
    jcb
    Sep 2005
    uk
    4,077
    don;t disconnect the battery, pain in the preverbial.
    take the keys out, put them in a box and hide the box in the house.
    I removed and replaced an airbag without disconnection.
    I reset my own airbag light and wiggled the underseat connection to make sure it didn;t come back on. 18 months on its fine!
    if you really want to sort it, get some electrical lubricant stuff (can't remember the name) like a super conducting silicon spray. quick squirt of that in the connector and you will be fine.
    get yourself a VAG COM cable. save yourself a fortune in Audi fees
    Jun 2007
    145
    did you have a vag com and reset it then or was there some other way?
    If i just clean up those connections under the seat then it should be ok? will the light just go out then?
    Lowlife's Avatar
    German Hardcore
    Jan 2007
    Herts
    566
    As an ex-mechanic I would not only advise disconnecting the battery but also to ground your self before touching any wires leading to the airbag, this reduces the danger of creating a static discharge and setting it off. We were warned plenty about airbags and pre-tensioner systems, I personally find it hard to believe that people would advise someone not to take all the precautions they can.
    Jun 2007
    145
    i guess its better to be safe than sorry.
    thanks
    205man's Avatar
    May 2006
    worcestershire, uk
    1,016
    id stick with what i and blue turbo have said and disconnect the battery/discharge air bag before touching, i cant belive people would risk, messing with one whilst still connected, even with the ignition off.
    airbags hold a charge in them for about half an hour after discconecting, and this is more than enough to set one off, im guessing people havent seen the effects/aftermath of one going off, or the wouldnt risk it
    its better to have a problem like finding the stereo code than the problem of removing an airbag from their face
    jcb
    Sep 2005
    uk
    4,077
    had a free download of rosstech VAG (see web) and a £12 eBay VAGcom cable.
    Jun 2007
    145
    Quote Originally Posted by 205man
    thanks
    good advice from you and blueturbo
    will let you know how i get on
