Sky InsuranceAH Fabrications
Results 1 to 11 of 11
    jimya4t's Avatar
    Sep 2006
    newcastle
    73
    forge dump valve
    just got a forge recirculating and blo off dump valve for very cheap sounds class but the car runs like **** if i put my foot down. could this be a boost leak? the valve can also change to a recirculating one aswell and runs really good. will i have to stick with the crap sound (old granny fart) of the recirculating 1 or will i be able to sort the bov one? any sugestions welcome.
    cheers jimy.
    Oct 2006
    Manchester
    724
    Hi Mate
    You have to set the SplitR one up , did you do this?
    Full fitting instructions here http://www.forgemotorsport.co.uk/con...duct=FMDVSPLTR
    Try that , there is also a note there to swap it round , did you do that?
    Sarah
    jimya4t's Avatar
    Sep 2006
    newcastle
    73
    yeah a swaped it. a think al probably have to stick with the recirculating setup
    Lowlife's Avatar
    German Hardcore
    Jan 2007
    Herts
    566
    Have you put it in the original place or intercooler side? If you want to run it as a BOV it needs to be intercooler side (for this you will need a fitting kit) or you wont get it to run properly.
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    London....Relocated to the Mid East
    2,230
    Hey Guys, I've got this DV, just wondering can I run it in the Hybrid mode? with it placed in the oem location? Mine was working fine for a week in the hybrid status, but yesterday I got some fault codes coming up. Anyone get this? I'm going to check it in Vag-com aswell
    2002 S3 BAM | Jabba Re-Map | Uprated Haldex | Koni adjustable coilovers | Neuspeed ARBs | Powerflex Bushes | ECS tie-bars | Dog bone | Eibach spacers | TTDA | T'Dynamics DV | Dieselgeek short shift | Toyos | MIJ Custom Exhaust | Sound system | Security Tints |
    Audi S3-BAM
    jimya4t's Avatar
    Sep 2006
    newcastle
    73
    Rite I got it sorted, I got sick of fanying on so i took all the boost and induction pipes off, cleaned them up and made sure every pipe was on tight put it all back together and put the valve to recirculating mode and its so much better! I think my old diverter valve was fooked, Its so much more responsive than before.
    One more question, Im thinking of going for an S4 but im only 21 nearly 22 do you think insurance companies will insure me? Also what are the main things to look out for?
    cheers.
    jcb
    Sep 2005
    uk
    4,077
    1) why would you run a non-recird valve when the car ECU needs one? you will always get some fault codes if you run an atmos DV on a recirc system
    2) how much you prepared to pay for insurance? you will always find someone to insure you. got an NCB?
    jimya4t's Avatar
    Sep 2006
    newcastle
    73
    1. you can block it off so its just a re-circ, i just got it for really cheap brand new off a friend and had vag com on and no fault codes.
    2. not really bothered Iv paid quite a bit with my other cars. my a4 1.8t has been the cheapest to insure lol. I just dont really wana be paying over 1500
    will do if i find a decent 1.
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,751
    Check confused.com
    I got my A4 when I was 19 and looked to change to an S4 when was 21 but then decided I would not have enough money to run the car while still being at uni.
    A4 1.8T Quattro
    jimya4t's Avatar
    Sep 2006
    newcastle
    73
    cheers al give it a go soupie
    jcb
    Sep 2005
    uk
    4,077
    ring the places that specialize in modified cars, they often beat others on quoting young drivers with high powered cars.
    I even put my wife's golf GT TDi through Adrian Flux now as they were better than Admiral!
