EM TuningMonster Motorsport
Results 1 to 12 of 12
Thread: need help guys
    billybravo's Avatar
    MODERATOR
    Feb 2005
    stockport england
    1,044
    need help guys
    ive got a 2 probs with my 1.8T
    1. the car idles fine and also drives ok but as soon as i hit just over 0.6 bar of boost the engine is really slugish like its farting as it tries to make more boost the prob gets worst like a missfire but i dont think it is.
    2.also while im here i replaced my coolant sensor last month the 4pin black one but my gauge only seems to work when it wants to. is the gauge on a diffrent sensor. there is a blue sensor with 2 pins next to the black 4 pin one could this be it
    cheers
    craig
    Also i dont have any codes coming up on vag
    help please
    TopGear Stockport / Longlife Exhausts /
    www.TopGearStockport.co.uk
    billybravo's Avatar
    MODERATOR
    Feb 2005
    stockport england
    1,044
    well to cure the second prob im going to get a new stat coz i think its sticking open.
    but i still cant slove the first prob HELP !
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,699
    You checked your spark plugs?
    A4 1.8T Quattro, FMIC, Coilovers, B&M short shift, 312mm Brakes, Stage 4 clutch, Awe Gauge, Uprated antiroll bars, plus more bits. Pics Here
    billybravo's Avatar
    MODERATOR
    Feb 2005
    stockport england
    1,044
    no
    billybravo's Avatar
    MODERATOR
    Feb 2005
    stockport england
    1,044
    checked the plugs there fine i dont think it has anything to do with the igintion side of things could it be the fuel pressure reg?
    billybravo's Avatar
    MODERATOR
    Feb 2005
    stockport england
    1,044
    ok ive found today that this only happen under full load the car hesitates then picks up
    any ideas
    thanks
    craig
    hiltoa's Avatar
    VAG erfahren
    Jul 2006
    on the edge
    299
    Squishy inlet pipe collapsing under boost?
    Nothing feels fast for long...
    2004 Audi Allroad 2.5 TDI L.E.
    Ebony Black.
    1991 VW Golf GTI 16v
    Tornado rot.
    billybravo's Avatar
    MODERATOR
    Feb 2005
    stockport england
    1,044
    i think it could be my mass air flow meter does anyone have a write up on how to clean them
    jimya4t's Avatar
    Sep 2006
    newcastle
    73
    i had the same problem. is it fine if you dont put your foot down and let it build up? does it just happen when you floor it or even just a bit? mine done this like i was kangarooing the car lol and it ended up it was the N75 valve. could be this?
    billybravo's Avatar
    MODERATOR
    Feb 2005
    stockport england
    1,044
    cheers i will have alook i did check it on vag and i could hear it working ok but i will swap it for one out of my mates see if that works
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,857
    Does sound like a dodgy plug to me, had the same problem, different car and it was the plugs.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    billybravo's Avatar
    MODERATOR
    Feb 2005
    stockport england
    1,044
    ok ive ordered a new set ngk bk6e's which i will set at 0.28 gap and im going to be getting a new maf tomorrow from eurocarparts or gfs parts lets hope all this does the trick
