Chris NottMonster Motorsport
Results 1 to 11 of 11
Thread: Induction kit
    mattpanton's Avatar
    Sep 2005
    Suffolk, UK
    123
    Induction kit
    My mate had an HKS induction kit for an impreza going spare, I took a look at it and figured I could make something to fit it to my B5, so I did
    The adaptor...
    And the fitted article...
    The sound it makes is pretty awesome when on full chat, and pretty much silent when then throttle is partially open, so it's really easy to drive quietly if needed. Not bad I think considering it's cost me nothing
    2001 A4 Avant SE 1.9TDi
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,698
    Good work, how u make the adaptor?
    A4 1.8T Quattro, FMIC, Coilovers, B&M short shift, 312mm Brakes, Stage 4 clutch, Awe Gauge, Uprated antiroll bars, plus more bits. Pics Here
    marms's Avatar
    Jan 2007
    Lincolnshire
    837
    Looks great and it looks like you're handy with a lathe too.
    But isn't the engine simply going to breath hot air now? Thats got to effect performance?
    I'm an optimist but I don't think it helps much.
    A3 8P 2.0TDi S-Line Sportback DSG
    scuttla 69's Avatar
    Blacked out TT
    May 2007
    Spain but am GEORDIE threw!
    206
    Bet that bad boy sounds the nutts, Good work on the adaptor u make that as a 1 off? Either way looks the ******s wish I could here it at 5 2 6000 revs lol!
    Space Invaders Champion
    Aug 2006
    65
    Good work.
    If I were you I'd remove the old airbox and refit the ducting at the front to increase the flow of cold air
    macattax's Avatar
    Oct 2006
    Ireland
    451
    Have to agree with johnie as it has no where to suck cold air in. But good work on the lathe all the same!
    All you have to do is find a way of getting more cold air flow so removing the old airbox might help you get some more air circulating.
    FACELIFT 99.5
    Current Mods: RNS-E MMI Conversion,Carbonio CAI,
    Baileys DV30 valve, Tinted windows, Xenon H.I.Ds, Bosch Aerotwins.
    Planned mods: Rieger Kit,Engine Tuning, Leather sports seats.
    Accomodation when the missus kicks me out for wasting money on a car.
    macca's Avatar
    Sep 2006
    Sussex.
    525
    i have adapted a mitsi evo 7 hks one to fit mine, but again hot air is a problem, but i have ran a pipe from the original cold intake area by the bonnet grille and then another up from the bumper vent on the side, also i am going to try and build a heat shield around that corner of the engine bay as the turbo and exhaust are the biggest heat producing areas on the 1.8T.
    1998 A4 1.8T Sport - For Saturdays
    2003 VW Golf MKIV R32 - For Sundays
    2000 Peugeot 406 HDi - For when it's raining
    1996 Kawasaki ZX7R - For when I'm late for work!
    Mods- Forge Dump Valve, The Engine Shop Power Plus based Engine (Low Comp. Forged pistons, Arrow H-Section Rods, Newman fast road cams, polished & ported head), 19" wheels, B&M Short Shifter, Greddy Turbo Timer, RS4 Grill, Weitec GTN coilovers, HKS modified air filter, Autobahn88 FMIC, ChippedUK custom map. Some Turbo mods ongoing.
    Biglockie's Avatar
    Aye you know it makes sense
    Nov 2006
    cumbria
    1,030
    Any pics macca?? thinking of goin down this route for my induction kit
    macca's Avatar
    Sep 2006
    Sussex.
    525
    yeah, i'll get some over weekend, also if anyone needs stuff there is jap performance based near gatwick in sussex. they import and break up jap performance cars and have loads of second hand stuff. mainly scoobies, mitsi's and skylines.
    you can get a nearly new HKS evo 7 filter and everything for £90 compared to £180 new.
    for my 3 inch custom exhaust i was thinking of getting a nearly new s/steel mitsi one and just cut and shut to fit the audi, that way i can use a lot of the pipework and the rearbox,.
    Biglockie's Avatar
    Nov 2006
    cumbria
    1,030
    Good idea fella I'll be in touch with regard to the filter crack fell I want one think its gonna be easier to fit in the small space.
    chris
    mattpanton's Avatar
    Sep 2005
    Suffolk, UK
    123
    Thanks for the comments guys, that picture of it installed isn't totally correct as the cold air ducting from behind the grill is in place and also the standard top cover is on covering it all in. The filter is sitting in the bottom of the original airbox so it's reasonably cut off from the heat, but not brilliantly granted.
    The adaptor was made as a 1 off on a lathe from an offcut of ally i found kicking about the workshop at work.
    A pic of how it is currently installed...
    and one closer up with the top cover removed...
