Sky InsuranceVolks Autos
Results 1 to 7 of 7
Thread: Brake Fluid
    A4 Quattro Sport's Avatar
    Top Gear
    Sep 2006
    Scotland
    36
    Brake Fluid
    Hi
    Does anyojne have any idea how much brake fluid the system on my A4 will hold?
    I am planning to change it and upgrade to a higher spec fluid.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,354
    When i flushed mine through, i ran around 3 litres through her. It was around 800ml per corner. I ran it till i knew it was well flushed and the fluid was 100% clean
    I ended up buying a 5 litre container and having enough left to run through my dads old Audi 80 a bit too
    Top Gear
    Sep 2006
    Scotland
    36
    Thanks.
    My dad wants to do his S3 as well, 5 litres might be just enough!
    enda1's Avatar
    Jan 2006
    Ireland
    439
    Did it last month on both cars.
    Volumes are from elsawin
    Audi recommend about 250 cm3 of brake fluid to drain out per caliper in the following sequence. Add 250 cm3 to the first caliper to allow the contents of the master cylinder to changed to make 500 cm3 from the first caliper
    1 - Rear right brake caliper
    2 - Rear left brake caliper
    3 - Front right brake caliper
    4 - Front left brake caliper
    On vehicles with manual gearbox the clutch slave cylinder should also be "flushed" with new brake fluid. Allow about 100 cm3 of brake fluid to flow out of the clutch slave cylinder.
    1.5 litres in total should do it.
    I'm not sure but if you car has ESP you need to hook it up to the diagnostics to change the fuid in the ESP circuit
    Enda1
    96 S6 2.3T
    99 A6 1.8T SE
    93 80 2.0 (gone)
    93 Kawasaki ZZR600
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,857
    Quote Originally Posted by enda1
    1 - Rear right brake caliper N/S
    2 - Rear left brake caliper O/S
    3 - Front right brake caliper N/S
    4 - Front left brake caliper O/S
    Depends where you look at it from...
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    Apr 2004
    12,354
    Maybe i was too worried,lol
    It also worked out cheaper to buy the big tub against a bunch of smaller ones.
    As stated bleed from the furthest caliper from the master cylinder to the closest.
    Good luck
    enda1's Avatar
    Jan 2006
    Ireland
    439
    As bryzan said start from the furtherest caliper from the master cylinder.
    This is as seen from the front of the car looking into the engine bay.
    I assumed you'd get my drift and as they say "assumption is the mother of all f*@k ups"
    Enda1
    96 S6 2.3T
    99 A6 1.8T SE
    93 80 2.0 (gone)
    93 Kawasaki ZZR600
