AH FabricationsSky Insurance
Results 1 to 9 of 9
    Apr 2007
    Surrey
    235
    After run mod S4
    Hi. I have seen articles about changing a the after run mod thermostat switch to that of a blue type that operates at lower temperatures.
    Has anyone fitted one of these as I read that it can only benefit the engine but would like to know if anyone off here has done the mod and if so is it recommended? Why did Audi not do it then?
    Car is a B5 S4 (2000 year)
    2003 S4 Moro Blue Saloon
    shineydave's Avatar
    Jan 2006
    Bradford, Yorkshire, UK
    904
    i've done it on my S4. basically the temp switch as standard only operates at quite a high temp so the afterrun pump doesn't come on unless it's red hot and you've been thrashing it. i guess they set it like this as a safety feature as it only runs when it's absolutely neccessary. a big mistake in my opinion, do the mod and you gain the peace of mind knowing the pump will run most days cooling the system and preventing the oil burning away from the shafts in the turbos.
    Dave
    "If that's the Turbo Fairy knocking tell Her I'm not in"
    Apr 2007
    Surrey
    235
    cheers mate gonna order one tomorrow from vagparts.
    GSB1's Avatar
    May 2006
    UK
    273
    Visit GSB1's Youtube Channel
    Even I managed it myself, go for it.
    Present: Ice silver B8 S4 s-tronic saloon (standard)
    Past: Agate grey B5 S4 saloon (MRC tuned)
    Hers: Volcano red 8P A3 Sportback 2.0 TDI CR 170 sport quattro
    Apr 2007
    Surrey
    235
    Well I have just completed the after run mod. It was an absolute nightmare though, just not budging first of all. Ended up shredding the plastic connector with my pliers after numerous attempts to remove with no sucess. Eventually after much soaking with oil and wiggling it eventually just popped out.
    ManicMunky's Avatar
    Sep 2006
    Chorley, Lancs, UK
    311
    Quote Originally Posted by s4mark
    that's what she said.....
    slightly more on topic, this is the radiator thermostat? that keeps the fan running on the radiator?
    - Andrew
    Apr 2007
    Surrey
    235
    its an after run pump switch that operates the system at a much lower temperature ensuring better cooling of the engine
    ManicMunky's Avatar
    Sep 2006
    Chorley, Lancs, UK
    311
    righteo
    tis a good idea!
    - Andrew
    shineydave's Avatar
    Jan 2006
    904
    it actually circulates the water in reverse around the cooling system after the engine is turned off, apparantly it's the best way to do it to prevent air pockets forming and already hot water trying to cool an even hotter turbo. just like a poor mans turbo timer, runs for anything up to 10 mins depending on how liberal you've been with your application of throttle and the ambient temperature
    Dave
