Sky InsuranceVolks Autos
Results 1 to 8 of 8
    stapo69's Avatar
    All hail the mighty quattro!
    Mar 2007
    966
    Cheapest/best place for MAF?
    Wanna change my MAF, car could run better i feel, think a change could only do it good on a car with 123k on the clock. Where's the best place to get em? Audi? Anywhere else?
    MRC-Powerflex-Hotchkis-Porsche-Compomtive-Vredestein-034-JHM-Apikol-EBC-FK-Labree-Vibrant-Recaro
    petewon's Avatar
    Dec 2004
    Newcastle
    514
    Could try cleaning it first and if that doesnt work I would go direct to somewhere like eurocarparts and buy a bosch one. Ive been tempted by cheaper ones in the past and had nowt but bother with them. Its a trade in part so should cost you about 70 with you old one as a trade in.
    Phantom_A4's Avatar
    Jan 2006
    Southwater, United Kingdom
    562
    Yep Pete is right, there is a surcharge on the old unit, so just take it off when you get there :P
    Exactly the same as you get from audi, without the mug you pricing!
    stapo69's Avatar
    Mar 2007
    966
    Cheers guys, I'll be doing that soon then.
    Feb 2007
    Manchester
    138
    Hello Lads,
    I have a A4 1.8 and I would like to know how to change the MAF sensor DIY. My car has 87000 on the clock and is a bit erratic at low rev and the rpm drops right after taking off. I am not sure that it is the MAF but just like stapo says, it can only do good.
    Otherwaise, how do you clean it?
    Cheers!
    petewon's Avatar
    Dec 2004
    Newcastle
    514
    Try unplugging it first to see if it sorts the idle out. Then if it is that, look for some info on cleaning it, I beleive you can use something like isopropanol or electronics cleaner, It might well be shot but cleanings worth a try if its gonna save you 70. Not sure exactly where it is on the B5 but I would guess just after the airbox.
    ZeroK66's Avatar
    Jun 2004
    Devon, UK
    246
    MAF cleaning although okay on an NA car is a waste of time on the 2.7T. Get it replaced. YOu can run the car disconnected, but unless the car is chipped (which yours is not) it is hard to tell the difference.
    As mentioned before... you need a health check done. Get the DV's checked over, make sure they have not popped, get a pressure test done for boost leaks & then get the MAF replaced. Guaranteed to transform the car... remap to be done soon too :P - then you will be grinning 24/7 :D
    I have got my old MAF sitting at MRC. Only covered about 2-3k and was bought in March 06, taken off the car in November 06.
    Facelift Imola S4 | Custom: K04's, Tubular Manifolds, 3" DPs-> 2.75" Catback | FMIC | H&R Coilovers + ARB's | Brembo 8-Pots | SS + DTS | 503HP/475lbs/ft | 1800W RMS
    Sold: Audi A4 (B5) 2.8 Quattro | Ivory Pearl
    Melted: Corrado - IHI 1.8 20vT: 343BHP
    stapo69's Avatar
    Mar 2007
    966
    Wanna get it off to MRC soon, when I can get the money together!
