EM TuningVolks Autos
Results 1 to 9 of 9
    Feb 2007
    Removig inside of doors
    Hi
    I know you need to remove the inside of the doors to get to the front speakers and replace them. I have removed the two screws (one back and one front) and now need to know if you simply wrench the door insides off or is there some trick to it. They seem stuck on pretty tight.
    Randomjim's Avatar
    Aug 2006
    Sussex, Uk
    2,747
    There two more screws in the door handle. Then lift it up and out over the door pin.
    Built in Germany, Perfected in England
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    577
    Hope this helps. Be careful and patient! Tricky bit is getting it back on and getting the door pin back through the hole lol
    Good Luck
    Si.
    2000 1.8t quattro Sport totally standard (ish)
    shineydave's Avatar
    Jan 2006
    Bradford, Yorkshire, UK
    904
    and make sure all the rubber buffers are in the slots where the hooks on the door panel locate
    Dave
    "If that's the Turbo Fairy knocking tell Her I'm not in"
    Jun 2003
    World of my own
    9,813
    Als make sure you wind the windows down before you start.
    NineNails's Avatar
    Sep 2006
    North Wales
    577
    A link that may help more...http://www.audiworld.com/tech/int49.shtml Obviously ignore the handle bit.
    Si.
    easytease's Avatar
    cheesypeas
    Nov 2005
    england, surrey
    426
    remember the sound deadening
    1999 1.8 SE A4 100% standard tank, all green.
    Alpine old skool
    Helix RS6 - PHD PRO 4070
    Coral 10" passive setup - PHD 2200
    Feb 2007
    Thanks to everyone who replied, all very helpfull
    I will check it out tonight, I do remember looking in the door handle for screws and not seeing any (as previous cars I've had have screws there) but maybe I was just blind.
    Jun 2003
    World of my own
    9,813
    There's just one up inside the cuff, remove this and push the plastic cuff down to reveal the main 2 screws.
