Volks AutosSky Insurance
Results 1 to 9 of 9
    Apr 2007
    Surrey
    235
    Instrument illumination S4
    Hi there.
    Just a quick question.
    Is there any way to increase the brightness of the speedo illumination? The numbers and needles are fine but the lamps in the middle i.e sidelights and traction control are a bit dim. Just wondering if you can increase the brightness.
    SamDude's Avatar
    Jan 2007
    London
    2,091
    There should be a 'scroll' wheel next to the headlight control to adjust the interior lights.
    Or try turning (not pressing) the speedo reset on the dash...
    A4 2.0TDI S Line (2008)
    MMI/Sat Nav, Parking System Advanced, Advanced Key
    Baker21's Avatar
    OEM+ A4 Avant
    Mar 2007
    Northants
    74
    Quote Originally Posted by SamDude
    It is the later of your too suggestions mate...
    Best regards,
    Baker21 - 'OEM+' AUDI A4 AVANT 2.6 V6
    Apr 2007
    Surrey
    235
    thanks all I will give it a try. I do not have the scroll wheel my lights are operated by a seperate stork by the indicators.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,525
    twist the left knob on the speedo for darker/lighter
    SamDude's Avatar
    Jan 2007
    London
    2,091
    Dont' forget to come back and 'Thank' us (me)
    shineydave's Avatar
    Jan 2006
    Bradford, Yorkshire, UK
    912
    on the S4 the instrument illumination is also controlled by a photocell in the speedo, look somewhere near the bottom left of the dial, you'll see a greyish circle. it detects the ambiant light and adjusts the dash lights to suit so in strong sunlight the lighting gets stronger but at night it dims them as long as you have the knob turned fully to the right. when it gets dark later on take a torch out there and try it
    Dave
    "If that's the Turbo Fairy knocking tell Her I'm not in"
    Baker21's Avatar
    OEM+ A4 Avant
    Mar 2007
    Northants
    74
    Whoops....I hadn't realised it was an S4 but you had both eventualities covered...
    Best regards,
    SamDude's Avatar
    Jan 2007
    London
    2,091
    Quote Originally Posted by Baker21
    Was used to the 'stalk' headlight control from my old A4. It was slightly fidgety...
