Badger5EM Tuning
    Glenn A4's Avatar
    Loving the A4
    Feb 2007
    67
    Ahhhhh big problem wheel nuts
    From my previous thread my locking wheel nut key being ****ed i found out today its not a audi part even though it looks like the newer shape locking wheel nuts. Took my car to a garage to see if they could do any thing and they totally sheerd the key off now its ****ed. I need to get them off but dont know how to go about doing it drill them out maybe. Worse thing is my brakes are grinding need new pads badly dont know what to do
    any help
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    579
    Take a visit to a decent tyre fitting place. They have allsorts of good stuff for dealing with this problem.
    Good Luck
    Si.
    2000 1.8t quattro Sport totally standard (ish)
    Dec 2004
    Lancs, uk
    263
    You can buy reverse thread 'Locking wheelnut removers' from most car or tool shops, but you need an air-tool to use them properly.
    Most competent garages will be able to remove them for you in this manner.
    What is the bolt pattern?
    I sometimes end up using a punch and a big hammer to try and get them moving.
    Glenn A4's Avatar
    Loving the A4
    Feb 2007
    67
    i finally got them all off the last one was a pig i welded a wheel brace on there in the end and broke it off like that. Tryied every thing else
    Jan 2006
    Deal, Kent
    468
    Well done mate, i've had this **** before.
    Luckily (or not) it was with the old type 3 pin ones, we had an old socket in the garage and hammered the crap out of it to get it in the other bolt, which was a "close" match.
    I know screw-fix do a set of 3 tools in a box for this horrid job! I'm sure mechanics have to do this quite often!
    2001 VW Passat 130 TDi Sport 6 Speed
    1999 Honda CBR900RR-X FIREBLADE
