Monster MotorsportEM Tuning
Results 1 to 8 of 8
Thread: decat
    Dec 2006
    decat
    decat on a 1.8t? is it worth it? much more power?
    i have a chipped 1.8t with an induction kit and cat back exhaust system. i see you can get decat pipes on ebay for around 120. get them cheaper anywhere else? could the car go into limp mode once fitted? could be a problem.... and also are they difficult to fit as they look difficult to get at... do you remove the cat from above or below? any help would be much appreciated. cheers
    joost's Avatar
    Nov 2005
    Lancs
    1,166
    I had a de-cat (bear in mind mine's a NA 1.8) and it felt smoother, whether it made any difference to the paltry output I'm not sure. In theory, it should free up some power as there's less restriction on the exhaust but then some will argue otherwise.
    You can get them from various places including ebay, MIJ and other bespoke exhaust places. Prices vary, as do the gains the manufacturers claim, best to shop around.
    Limp mode unlikely AFAIK, the lambda sensor's on the downpipe IIRC, the cat is behind that. I may well be wrong though. Prob need to get at it both from the top and underneath because of where it is. Again, I could be corrected very shortly!!
    Have you not considered a high-flow cat? Slightly more expensive but easier come MOT time...
    Justin
    2001 VW Golf 2.3 V5 (170) Highline, Indigo Blue - standard, for now...
    A4 (B5) SE with a few slight amendments here and there (sold)
    Biglockie's Avatar
    Aye you know it makes sense
    Nov 2006
    cumbria
    1,030
    Go for the decat, the limp mode is triggered when you over boost (I think)
    the removal of the CAT will free up some power how much I couldn't be sure but it will be smoother on pick up.
    Any engine especially turbo'd units do benefit from de cats
    billybravo's Avatar
    MODERATOR
    Feb 2005
    stockport england
    1,044
    check this write up i did about 4 weeks ago and search the forums for THS decat install. the post cant be that far away
    http://www.top-end.com/freebies/down...write%20up.pdf
    i would defo go with a decat i love mine
    TopGear Stockport / Longlife Exhausts /
    www.TopGearStockport.co.uk
    Beerzo's Avatar
    Masa'warty 3200... Talk To Me!
    Feb 2006
    Scotland
    1,241
    I have recently fitted a de-cat pipe to mine and the turbo spools up quicker plus you can hear the turbo spooling aswell which is pretty cool. Would need to get a dyno reading to see what the power difference is but yes there is a noticable difference. I got mine for £80 from a fellow AS member.
    £120 seems quite high i have seen them on eBay for alot less brand new.
    macca's Avatar
    Sep 2006
    Sussex.
    525
    billybravo, since doing your decat i take it that everything is good and well worth the effort?
    after reading your write up i have decided to get one in a few weeks time, once i've caught up with sorting other bits out. i'm only fitting until i do my big turbo in the winter, but for £130 seems like it's worth the effort.
    1998 A4 1.8T Sport - For Saturdays
    2003 VW Golf MKIV R32 - For Sundays
    2000 Peugeot 406 HDi - For when it's raining
    1996 Kawasaki ZX7R - For when I'm late for work!
    Mods- Forge Dump Valve, The Engine Shop Power Plus based Engine (Low Comp. Forged pistons, Arrow H-Section Rods, Newman fast road cams, polished & ported head), 19" wheels, B&M Short Shifter, Greddy Turbo Timer, RS4 Grill, Weitec GTN coilovers, HKS modified air filter, Autobahn88 FMIC, ChippedUK custom map. Some Turbo mods ongoing.
    billybravo's Avatar
    MODERATOR
    Feb 2005
    stockport england
    1,044
    well if you use the one ive got 3" THS ATP pipe it will work well with the Gt28R
    and yes in my eyes it was worth every penny. if you need any help just give us a pm
    cheers
    craig
    A3_Turbo's Avatar
    Swaying towards IHI....
    Jul 2006
    Virginia water, surrey
    1,441
    I Lost 10bhp on the rollers with my decat, Took it off and put a miltek cat in,
    It was alright then.
    I had nothing but trouble with my decat....
    Jason
    A3 1.8TS
    K03S,Pro Alloy FMIC, Neuspeed TIP, Forge 007P,Jabba Stage 2, BMC CDA, Turbo Back Miltek,H&R Cup Kit,H&R Arb's,18" Cup 3's Wrapped in Parada Spec 2's, Facelifted, 10k Hids, Dewipered, Debadged,S3 Interior, S3 Rear bumper, S4 Front bumper, Brembo's, Momo Team, LCR Splitter.
