Badger5Monster Motorsport
Results 1 to 10 of 10
Thread: wiring to seat
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    wiring to seat
    Hi my new leather seats have a electric lumbar adjustment on both passenger and drivers.
    Whats the best way to run power to the seats? hopefully i dont have to run it to the battery.
    i dont know it they have have a permanent live or not?
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    Jun 2003
    World of my own
    9,813
    It'll be ignition on live. They'll draw quite a bit of current as well I imagine so I'd run a fused supply to the 75x terminals above the drivers footwell if there's one that's switched with the ignition.
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    i assume the other connection is earth?
    also where do you source your spade connectors halfords are so expensive for small amount
    i need assortment on spade different sizes etc.
    Jun 2003
    World of my own
    9,813
    Maplins
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,850
    I would do it one of two ways.
    1st I would say use a relay using the main power from the live power bar under the drivers side removing the lower dash and using the ignition as the on and off feed for the relay.
    2nd Go straight to the power bar and just have a fuse so the seats are live all the time.
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    are you saying use existing relay or buy a new relay if so which one
    thanks
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,850
    Buy a new relay.
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    This company are good but they have a minimum order, always buy some heat shrink, much better for covering terminals, soldering etc than tape.
    My electric lumbar support works with the ignition off and they key out BTW
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    Jun 2003
    World of my own
    9,813
    Any 12v relay will do the job, but a bit unnecessary, just a fused lead from the 75x terminal is fine. You only use a relay when the trigger is low current.
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    sorry forgot the link in last post, here it is http://www.vehicle-wiring-products.co.uk/
    Chris
    See my images @
