    hiltoa's Avatar
    VAG erfahren
    Jul 2006
    on the edge
    299
    180bhp standard boost psi?
    Guys and Gals, a question for y'all:
    I've just wired up my boost gauge, taking the vacuum feed off the pipe between inlet and fuel regulator.
    Took the car for a run, and it's showing up to 12psi (0.8bar) @ WOT under load - I was expecting around 6psi.
    I get negative pressure on the overrun (> 22inHg) and the needle sits happily around 0 at idle. If I floor it in first it will only hit 6psi, but in the higher gears it's easy to build over 10psi.
    I know the car is standard (I've not fitted my n75j and 710N yet) so does anyone have any idea why I'm getting such high readings? Or is this how it should be?
    Cheers!
    Last edited by hiltoa; 24th March 2007 at 19:57. Reason: add Bar for those who use it!
    Nothing feels fast for long...
    2004 Audi Allroad 2.5 TDI L.E.
    Ebony Black.
    1991 VW Golf GTI 16v
    Tornado rot.
    johnyj's Avatar
    Jun 2004
    253
    ive just fitted my gauge to a 18t 150bhp and goes up to 0.5 when booted
    and -0.5 when at idle
