Baker21
OEM+ A4 Avant
I have been looking into replacing the headlamps on the A4 Avant as they are both showing signs of wear.....
Not many options open as far as I can see, ideally Xenon would be the best but this is too expensive and I wish to keep as close to an OEM look as possible so I have come across these, which I have seen on other 'forum member's' cars and was wondering.........what is involved in fitting these:
http://cgi.ebay.de/Audi-A4-FACELIFT-DE-Klarglas-Scheinwerfer-Paar_W0QQitemZ300092887409QQcategoryZ57309QQrdZ1QQcmdZViewItem
The seller's auction translates into the following:
These headlights can be used also for the older Baujahre (94 / 99), however then the wall plug must be changed and be removed the sheet metal in the inside of the fender, to which the turn signal is fastened, since the Facelift headlight is a complete unit with turn signal. This change is to be accomplished at very small expenditure and lends to the vehicle afterwards a completely new Optik(Facelift)
So what does he mean by the 'wall plug'? Has anyone fitted these headlamps and if so how difficult is this modification?
(I appreciate that this headlamp is a complete unit and the current headlamps are two parts)
Any help or explanation on this would be most appreciated.
