Badger5JMB Retrofits
Results 1 to 19 of 19
Thread: MOT Failed
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    MOT Failed
    Just got back from MOT Centre and car failed the MOT for the 1st time on the outer CV Gaiters split on BOTH sides! couldnt believe it oh well sh*t happens got a quote from my local garage who says 100 + VAT for labour for fitting both gaiters.
    Audi did not have the part in stock he suggested to try VW. So got CV boots from there 28 inc vat each.
    i would only fit genuine parts in this case last thing i want is the boot falling off as the copy ones seem to use plastic tie wraps.
    MOT gone up as well @ 50!
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    shineydave's Avatar
    Jan 2006
    Bradford, Yorkshire, UK
    912
    takes half an hour a side if you have the right tools including getting the wheels off
    Dave
    "If that's the Turbo Fairy knocking tell Her I'm not in"
    smitch's Avatar
    Sep 2006
    1,585
    I had new front discs and pads fitted last week and now i've got a wheel bearing gone.
    S4.
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    Quote Originally Posted by shineydave
    half and hour thats quick i wish haynes made a manual for this car! i dont like taking it apart and finding out i dont have the correct tools etc for the job.
    i looked in the box of the gaiter and it comes with a massive bolt in there??
    i done it once on my old astra astra gte16v mk2 got in a mess trying to find the circlip...
    DIPS_A4's Avatar
    SEAT LEON CUPRA R (225)
    Mar 2006
    Leicester
    566
    I think out b5s are getting a lil tierd my wheel bearing is gone as well
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    The only special tool you will need is a 14mm allen socket to remove the big bolt.Once that is off, you should have enough play to get the shaft out by turning the steering to full lock.
    Once out, put the bolt back in and tighten, this will draw the joint off, obviously that will enable you to swap out the dodgy gaiter.I know i had both mine go too.
    The joint will push back on once the gaiter is put over the shaft,replacement is the oposite of removal etc etc
    205man's Avatar
    May 2006
    worcestershire, uk
    1,016
    rasa4 ive got a pdf file on the dismatle/rebuild of the a4 drive shaft if any good to you, it will at least give you idea how it all comes apart etc.
    pm me your email addy and ill send it to you
    alan
    Phantom_A4's Avatar
    Jan 2006
    Southwater, United Kingdom
    562
    Don't forget to re-grease aswell!! :P
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    that sounds really easy
    does this bolt go through the main brake disc? so once the wheel is off is this the only thing i need to take off?
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    Quote Originally Posted by 205man
    alan
    cheers mate is it for a 2.4?
    PM sent
    Road Razor's Avatar
    Tyne & Wear
    390
    Unfortunately the same thing happened to me last month when I took mine for an MOT, just one of the CV gaiter split. It failed for the first time @ 66k miles. Had the front brakes & pads replaced at the same time.
    A4 2.4 V6 2000.
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    mines only done 54k i put my CV gaiters splitting early due to my neighbours new wife keeps parking her car just near my drive (told her a million times to leave more space she does it for a few days then does the same thing after that)
    and other cars parking on the other side of my drive thus leading me to nearly doing full lock when getting in and out of my drive.
    Parking on my road is getting tight now lucky i have a driveway and a garage.
    PhilR's Avatar
    One Ate Tea
    Jan 2006
    UK
    330
    I did mine not too long back car had about 65k on and it was split, just put a discount centre jobbie on, came with the metal clamps though
    My driveshafts are dead from ahving the car too low though click click click click
    scrupes's Avatar
    bloody great extension bodger
    Jul 2004
    at R88PERS beck and call AGAIN!!
    236
    Quote Originally Posted by rasA4
    i wish haynes made a manual for this car! ..
    they do! it dosent cover the engine or the quattro system but the steering, suspension, brakes, front driveshafts and cv joints etc are the same on all A4's
    just a thought
    my car failed before on two tyres and a bulb, when i checked the tyres all four were below 1.5mm ? strange
    good luck with the new boots!
    Lowlife's Avatar
    German Hardcore
    Jan 2007
    Herts
    566
    Hope u get it sorted mate!...
    Biglockie's Avatar
    Aye you know it makes sense
    Nov 2006
    cumbria
    1,030
    Mine has split too, made a right mess of my wheels!!!!! not impressed!!
    Gonna get a new one fitted this week, I'll check my CV joints to phil as mine was dropped on its ass too.
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    mines only dropped 35mm i hope that doesnt cause a problem?
    Nov 2004
    Kent, UK
    138
    Lowering the car in itself shouldn't damage the driveshaft CV joints as they are designed to work at all angles of suspension travel.
    Generally what kills them is a lack of grease which causes dirt and corrosion to get in. If you have a CV gaitor split don't delay in getting it done as the grease gets flung out every where and water and dirt can get into the joint.
    John
    B5 S4 avant - for sale!
    Allroad 2.7T
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    Quote Originally Posted by QuantumJohn
    John
    getting it done on saturday
