Chris NottJMB Retrofits
Results 1 to 7 of 7
    951
    951's Avatar
    Feb 2007
    North east
    493
    Snapped dipstick
    The collar that hold the dipstick in has snapped off in the metal tube,ive bought the new collar from the dealer for Ł2.03. It it easy enough to change and does the metal tube come off the engine easy enough ???
    A4 Avant 1.8T Sport (183 bhp).
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    you got the car? if not i hope the seller hasnt "snapped" it off so you cant see the oil?
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    Pliers to romove the snapped bit and the new one just pops on,simple !!
    951
    951's Avatar
    Feb 2007
    North east
    493
    Just picked up the car,you can still use the dipstick but its just not secured. As it happens ive just checked it and the garage have removed the snapped collar already and put dipstick direct into the tube so it should be a simple case of just fitting the new collar !!
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    oh ok get some pics up of your motor asap
    filipharvey's Avatar
    Amusing Tagline
    Aug 2006
    Fakenham, Norfolk
    518
    The bit the dipstick goes into has snapped on mine too- is this the bit you mean? I thought that went all the way down to the bottom??? Simple fix then?
    Audi A6 1.8T Avant
    Alfa 156 3.0 V6 Veloce
    951
    951's Avatar
    Feb 2007
    North east
    493
    There is athe main metal tube that is attached to the engine and there is a plastic sleeve push on top which the dipstick pushes into. Apparenty a common fault on a4's so im told. the garage had just put a rubber tube round mine as i temp fix so i had to remove the old snapped piece with a pair of pliers,to get access you need to remove the rad bottle and then just remove the snapped part and push the new piece on . took me about 10 mins !!. The part number is v053 103 663 / ab076 v050 103 663/g And costs £1.73 + vat which is £2.03.
