    Sep 2006
    21
    Help with recorded fault code
    Hi All,
    Reading the fault codes on my car using a snap on diagnostic tool, it comes back with manifold pressure below minimal level intermittent.
    Anyone have any ideas as to what this means? It's had new MAF, dump valve and N75 but code still appears and it seems a little flat.
    Damian
    Feb 2007
    Heckington,Nr Sleaford, lincs
    16
    RE lack of power
    Faulty MAP sensor? Loose/split boost pipes/vaccum pipes?
