Sky InsuranceEM Tuning
Results 1 to 20 of 20
    Oct 2006
    10
    Speaker upgrade........
    Hello
    Ive just replaced my concert headunit for a pioneer avic x1 unit (couldnt put up with volume crazyness anymore)
    Seems that the pioneer is to powerful for my front speakers, they've developed a vibrating sound....... can they be easily changed??
    Also done a seach to see what size they are but cant find anything!!
    Any help will be cool!!
    joost's Avatar
    Nov 2005
    Lancs
    1,166
    I think they're 4" woofers/mid and 1" tweeters as standard but you can fit 5.25" (17cm) at a pinch. You'll need adapter rings for the woofers/mids to fit the 17cm ones - not too expensive though. Only problem is, as they're mounted on the doorcards, the sound isn't too great. I've actually put some silicone sealant around the woofer mountings and it's improved the sound quite a bit. I've not tried to get sound off quality though!!
    Justin
    2001 VW Golf 2.3 V5 (170) Highline, Indigo Blue - standard, for now...
    A4 (B5) SE with a few slight amendments here and there (sold)
    dsmclark40v's Avatar
    Sep 2006
    Hampshire
    715
    I normally go to www.bassjunkies.com as you can select your car and it tells you what speakers fit. But i wouldn't buy from them as they are expensive. i changed my head unit and i get the same thing with my front speakers but haven't got round to changing them. are you back speakers working because i had to rewire mine as it had a little amp for the back speakers which i ended up taking out as it would make them cut out at the slightest hint of bass as the head unit was too powerful for it. but it works ok now but i do need to upgrade my speakers at some point
    Oct 2006
    10
    Thanks fo the replys, I got an autoleads harness that i plugged into the pioneer wires! once i hooked up the remote wire to the unit the rears worked ok!!
    Seems to be just the fronts that vibrate and sound poor!!
    Randomjim's Avatar
    Aug 2006
    Sussex, Uk
    2,747
    I uprated mine with a set of jbl 5.25 components and fade slightly to the rear.
    Standard speakers are only paper so they don't last long.
    Built in Germany, Perfected in England
    ZeroK66's Avatar
    Jun 2004
    Devon, UK
    246
    Many people recommended the rainbow 235slx deluxe components which I had fitted and they do sound great running off my amp.
    Be warned though, you cant really put any bass through the front speakers as the mounting point is not solid enough. I have mine running off an amp in the boot with the crossover freq at about 80 I think
    Facelift Imola S4 | Custom: K04's, Tubular Manifolds, 3" DPs-> 2.75" Catback | FMIC | H&R Coilovers + ARB's | Brembo 8-Pots | SS + DTS | 503HP/475lbs/ft | 1800W RMS
    Sold: Audi A4 (B5) 2.8 Quattro | Ivory Pearl
    Melted: Corrado - IHI 1.8 20vT: 343BHP
    ding dang do
    Apr 2007
    Up North
    185
    sorry to bring this back to life, but thought i would ask on here rather than starting a new thread!
    I'm changing my full stereo system. i have bought 4" + 1" front speakers, do i need any adapters or brackets? i have the single concert stereo at present (the wide one and i have the blanking plates for this...). Bog standard with CD changer that is being removed!
    Going to install amp, subwoofer and 6 x 9s in rear, but will be running new cables for this anyway. i have no issues with the rear, just not sure about the front as i've read several different things and all are unclear...
    Jun 2003
    World of my own
    9,813
    Yes you need adapters for any sort of aftermarket speakers. The plastic ones are readily available but be warned they're pretty feeble and they don't fit very well, so will probably need silicone, or better still use them as a template and make your own from MDF. This at least means they fit properly and also give the speaker something slightly more robust to kick against. As already mentioned regardless of what you fit you can't get any decent mid bass from them without rebuilding the door cards.
    How are you planning on fitting 6x9's in the rear? The stock units are only 6.5" coaxials
    ding dang do
    Apr 2007
    Up North
    185
    having them done by someone who can! not a job i'm willing to do on my own, plus doing the front will save me 35. i believe they will be cut out for the rear and connected to the amp. Unless you have any hints and tips...
    They are also fitting the head unit, amp and subwoofer. just realised, is the standard wiring ISO compliant or do i need a convertor?
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    I have all active speakers according to the spec list is it even worth changing them can they still run off the existing amps or is at replace the lot job?
    A4 Avant project now started ! see this thread ! http://www.audi-sport.net/vb/a4-s4-forum-b5-chassis/43296-bit-project-going.html
    If you think my post had a usefull purpose please say thanks
    Jun 2003
    World of my own
    9,813
    The standard power wiring is on an ISO connector, but you'll have to swap over the perm live and ignition on live as Audi wire them back to front.
    Why would you fit 6x9's in any car? let alone one that only has holes for 6.5 inchers. They are generally regarded as the worst shape speaker for sound quality.
    The rear shelf is made of sheet steel so I wouldn't recommend cutting it, just get some 6.5" coaxials.
    Markey, unless you have Bose, then only the rear speakers are active the fronts run off the head unit.
    ding dang do
    Apr 2007
    Up North
    185
    cheers bud, will go back to the shop tomorrow and change the speakers and get the front brackets!
    I take it i just run new cable from sub-woofer amp (its bridged) to the new 6.5 rears? or will it be enough connecting to original wiring? (sorry, cars are not my thing! PCs yes, cars i do little to no work by myself!)
    Oh, one final thing... dont really wanna run the amp power cable the length of the car to the battery. is there a more local / near power source? (would the original CD Changer have power?) since no cutting am gonna get my mate to do it, not professional, but competent!
    Jun 2003
    World of my own
    9,813
    There is no original wiring, the stock amp is bolted to the left speaker and no you have to run new power. There is nothing in the car that has a spare 30-40amps that you can use, especially not a CD changer which uses about half an amp (if that).
    ding dang do
    Apr 2007
    Up North
    185
    ok, cheers! so its a start from scratch then!
    can i just bring it round to yours? would be a lot easier!! :P:
    ZeroK66's Avatar
    Jun 2004
    Devon, UK
    246
    Quote Originally Posted by AndyMac
    I would pay "fair" money to have this done for me... my fronts could really do with better mounting. You got the time Andy?
    cocain's Avatar
    RAA RAA like a dungeon dragon!
    Aug 2004
    The Sticks
    155
    Smile
    Quote Originally Posted by ZeroK66
    Was gonna offer but saw that you live in devon.
    the A4 is not hard to do you just need a jigsaw and a little time, but the a3's are buggers as you have to mount on the door card. the a4 you mount to the actual door and if you dynamat the door and seal everything nicely they sound great.
    Jun 2003
    World of my own
    9,813
    B5 A4 mount to the door card as well I'm afraid.
    Jun 2007
    11
    If i am swapping in aftermarket 6.5" in the rear can i not connect them to them existing wiring? Has anyone mounted a better sub in place of the terrible one that audi appear to have got from Fisherprice and shoved in my rear arch? Thanks
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,857
    Put a 10" in an enclosure and velcro it to the boot carpet, you should notice some serious improvement (plus an amp of course)
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    easytease's Avatar
    cheesypeas
    Nov 2005
    england, surrey
    426
    Quote Originally Posted by A4Quattro
    and remove the reat speakers to allow more bass into the cabin, espically on the sealed boot a4's.
    custom door pods is THE way forward :D
    1999 1.8 SE A4 100% standard tank, all green.
    Alpine old skool
    Helix RS6 - PHD PRO 4070
    Coral 10" passive setup - PHD 2200
