Chris NottBadger5
Results 1 to 23 of 23
    Rich's Avatar
    Rollin on boost mother hubbards
    Jan 2007
    Basingstoke
    373
    Engine speed drop when using electrics
    Just wondering if this is normal or anything to worry about as I have never noticed it in any other car I've had.
    Basically the easiest way to observe it is if the enginee is idling, stays about 900 rpm, if I then pull up the windows the engine speed drops to about 750-800, hear it start to struggle the the speed goes back up to about 1200 rpm, then drops down to 900. This happens if I do windscreen wipers or anythign really just not as noticeable.
    Probably nothing to worry about but why does this happen, surely the engine could just stay at a constant speed of 900rpm (like it would in any other car I've had), the battery voltages are fine although you can also see the needle drop slightly when you do this as well before going back up.
    Jul 2006
    324
    nothing to worry about it happens to all cars to a certain extent.it is all to do with battery capacity(aH),when the car is idling the alternator output is very low and the battery is doing all the work,just squeeze the accelerator a touch and you will see the voltmeter go up.think of being in a traffic jam-engine idling,heater on full,lights on,rear demister on,stereo on,the battery is having a hiding the current draw is massive,you need a good 20 minute run to recharge the battery to its normal state(about 13.5 volts).
    Jun 2003
    World of my own
    9,813
    Mine doesn't do this, your battery is probably on its way out as it obviously can't even cope with the small current drawn when putting the wipers on and is relying on the alternator to provide the extra current.
    Rich's Avatar
    Jan 2007
    Basingstoke
    373
    Hmmm, thought that might be the case, then again the voltage always says like 14V :S. but also voltage != current so I guess it might be fecked, hasnt been replaced in 6 years. Will any standard 12V thing I get from halfords do the job?
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,509
    Pretty much yeah,as long as it's the right fitment,as the gap where the battery goes is a bit restrictive
    shineydave's Avatar
    Jan 2006
    Bradford, Yorkshire, UK
    912
    all cars do it, try it in someone elses and see
    Dave
    "If that's the Turbo Fairy knocking tell Her I'm not in"
    Rich's Avatar
    Jan 2007
    Basingstoke
    373
    Hmmm, mixed opinions ;P
    Might see if I can borrow a newer battery to test just encase Andymac is right
    scrupes's Avatar
    bloody great extension bodger
    Jul 2004
    at R88PERS beck and call AGAIN!!
    236
    I'm not saying andymac is wrong, but i have experienced this in all my cars! esp when swithching rear demisters, blower fans or electric windows.???
    you've done well to get 6 yrs from a battery tho!
    Lowlife's Avatar
    German Hardcore
    Jan 2007
    Herts
    566
    Turning anything on that draws a lot of amps usually results in a momentary drop in engine speed but it should pick up again after a couple of seconds. As long as it recovers I wouldn't worry about it, if you are worried though get it checked out, most decent auto factors can check a battery and it'll give you peace of mind...
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    579
    Quote Originally Posted by Rich
    NO. Don't get a Halfrauds battery, they are ****e!. If you love your car treat it to a Bosch Silver Top. Spec is 75Ah 729 Cold Crank, Bosch part No 7HN. The one I removed from my V6 was a Halfords brand less than 4 yrs old and knackered. It was only rated at 550 cold crank, under-powered in my mind. A cheapo battery is false economy I reckon. I paid 72 all in for mine from local Bosch agent.
    HTH
    Si.
    2000 1.8t quattro Sport totally standard (ish)
    Rich's Avatar
    Jan 2007
    Basingstoke
    373
    Cheers, at least I know that one will fit niceley as well.
    Jun 2003
    World of my own
    9,813
    If it's 6 years old the it'll definately need replacing.
    Rich's Avatar
    Jan 2007
    Basingstoke
    373
    Right picked up a battery today, how do you get the battery out?! I can take off the lil cover that just slides off but then theres the big long black one that goes the length of the bonnet, blocking access to remove ones battery!
    Apr 2004
    12,509
    That cover will come straight out. Pull the rubber seal that runs along the back edge and the cover will slide forward and off
    Rich's Avatar
    Jan 2007
    Basingstoke
    373
    Reet, I installed the battery, got the Bosch 6HN in the end. First thing I noticed was changing gears as I reversed and drove out my road - it feels a lot more fluid and easier to press the clutch. not that it was hard before but its definatly a noticeable change -is the clutch electrically controlled or somthing? Also the steering felt a lot lighter to turn as well. Wasnt expecting those 2 things to happen so its def worth swapping the battery out if you think its getting on a bit.
    However - back to the original problem - the engine speed still dips when using electrics. ie idling at 900rpm, wind the windows and it drops to 700 before shuddering (head lits dim at the same time) and bringing the speed back up. I'm not sure if it takes a bit of time to "run in" the new battery tho, as I only had time to take it out for 15 mins.. I also remember reading it will of reset the ECU so might take a few miles to settle in completly anyway?
    Jun 2006
    NH, USA
    59
    Sounds like your altenator is on its way out
    NineNails's Avatar
    Sep 2006
    North Wales
    579
    It may be worth just replacing the regulator (it includes brushes)on the alternator. I think it's replaceable on your model. Cost me about 12 for mine. Hope you've not got worn slip rings.
    Si.
    Rich's Avatar
    Jan 2007
    Basingstoke
    373
    Damn, I have no idea what a regulator/alternator or slip rings are really or how to replace it them..
    Anyone know a site where I can buy a replacemetn regulator/alternator? If it's cheap then I might as well just swap it out anyway to rule it out as a couple of people think it could be alternator related.
    Update: DOes this look like what I might need?
    http://www.car-stuff.com/audialternator.htm
    Or does anyone know any places in the UK I could order one from?
    Rich's Avatar
    Jan 2007
    Basingstoke
    373
    Bump :P
    Anyone got any advice on the Alternator? Might pop into Camberley auto parts and see if they have one for a 1.8t
    Apr 2004
    12,509
    I have a spare alt you could try, its from a non aircon 1.8t 70 amp jobbie
    NineNails's Avatar
    Sep 2006
    North Wales
    579
    Hi. The 'slip' rings are the circular contact around the top of the spinning coil, they transfer the DC into the regulator via the brushes. On a 2001 car I doubt if they are worn, and thinking about my previous post I don't think the regulator/brush assembly is servicable on your model.
    Alternators are expensive to replace on a guess. You should get it tested first.
    Do you have a multi-meter? Here's what you do - start the car, make sure all the accessories are off and rev up the engine to a fast idle. Set the Voltmeter to the DC scale (not AC or Ohms). Measure the voltage across the battery terminals - red lead of the voltmeter on the positive terminal, black on the negative. The voltage should read around 14 volts. If it reads less than 12 volts you may indeed have a failed alternator and you can skip the next step. Next, turn on the heater, the rear window de-fogger, the radio, the headlights and anything else that draws power. Now rev up the motor and watch the voltmeter. It should still be reading around 14 volts. If it reads lower than 13 volts the chances are that your alternator is failing.
    Do this test before you go shelling out for a new one...It may not be the problem.
    Si.
    Jun 2003
    World of my own
    9,813
    Alternatively, trickle charge the new battery overnight, and if it continues to cause problems then it has to be the alternator - about £180 fitted at a specialist, or £400 from Audi.
    Rich's Avatar
    Jan 2007
    Basingstoke
    373
    Well the car has a volt meter on the dash - when I start the car its on around 14V and drops maybe half a volt when loading it, at the same time the engine speed dips. When the idle speed recovers the volts go back up as well to the original position. Probably only a second from the speed dipping and volts dropping to recovering.
    I spoke to another couple of people who seem to say its nothing to worry about or it could be the alternator on the way out. I'd rather fix it sooner rather than later I guess I need to find a "specialist" in the Basingstoke area then that knows how to swap one out on my model to be sure. hmm
