Well im sick as a chip, bearing gave up bigstyle on my turbo (little k03) last night.
As some may remember i had a problem with the actuator on my cars original turbo (didnt know it was the actuator till i took it off else i would have bought a replacement one) so i bought a supposed low mileage turbo from a breaker fitted it about 6 months ago and all was well till it started whistleing on the way home last night, i knew what was up so tried to keep revs down to just get home (which was no more than 2 miles) and investigate. Unfortunately rounnd the corner from home the bearing must have given up completely and started ratteling like hell so i shut it off and got towed home.
I had a look when the car had cooled, whipped of the airbox and intake pipe and was "pleased" that i found something wrong with the turbo.
I took the turbo off when the car had cooled, luckily all of the turbine wheels are intact but you can pull them back and forth in the housing by about 6mm
So im carless till a new actuator arrives and then i can put my old turbo back on which i know has only done 40K, moral of the story buy a v6 !
