Sky InsuranceBadger5
Results 1 to 7 of 7
    Feb 2003
    Tyne&Wear UK
    22
    1.9 Tdi Shreading Auxilliary Drive Belts ?
    In the last 5 months ( 6,000 mls ) my '76 A4 Tdi 110 has shed 2 and is currently on it's 3rd Aux Drive Belt ( Fan; Power Steering and Alternator Belt )
    As the current Belt is still fitted I can see that it seems to be riding over the Pulley Ribs towards the front of the car, this suggests that there is an alignment problem but why after 150,000 mls in my ownership should this start happening ?
    Robert.
    treblesykes's Avatar
    Nov 2004
    york
    688
    dont know for sure but try checking the tensioner,maybe be short of tension or wobbly
    Feb 2003
    Tyne&Wear UK
    22
    Good suggestion, would account for Belt crossing over Pulley Ribs, I also have a '98 A4 so will compare Tensioner forces. Will report back.
    Robert.
    Feb 2003
    Tyne&Wear UK
    22
    Latest Belt fitted and will monitor daily ( ? ) Compared Tensioners on both Audis and the seem the same. Spoke with Continental who manufactured the Belts, they were very receptive of the concern and will talk with their German colleagues and supply feedback.
    Robert.
    shineydave's Avatar
    Jan 2006
    Bradford, Yorkshire, UK
    912
    could it be worn bearings in one of the driven components?
    Dave
    "If that's the Turbo Fairy knocking tell Her I'm not in"
    Jul 2006
    324
    try putting a straight edge(steel rule etc)across the 2 pulleys to check alignment
    marmite's Avatar
    Counting the Tesco Club points
    Jul 2006
    Barnet
    1,070
    THis used to be a common fault and the tensioner needed to be replaced, we used to get loads of cars coming in with snapped belts
    When looking down at the engine from the n/s you can see the pully on the poly belt tensioner, the spring goes out of shape and the tensioner pully goes out of alignment causing the belt to snap
    Job is fairly straight forward but the bolt holding the tensioner can be very tight and seize in plus you need a special tools to hold it steady while you undo the bolt
    Audi RS6 Daytona GreyLoving all 455.7BHP of her
