EM TuningVolks Autos
Results 1 to 7 of 7
    teambeer's Avatar
    Feb 2007
    Isle of man
    9
    Question Help with Lambda sensor
    I just ran a vag-com check on my s4 out of intrest and its come up with:
    16538 - Oxygen (Lambda) Sensor B2 S1: No Activity
    P0154 - 35-00 - -
    17536 - Fuel Trim; Bank 1 (Mult): System too Lean
    P1128 - 35-00 - -
    P1128 - 35-00 - -
    17528 - Oxygen (Lambda) Sensor Heating; B2 S1: Open Circuit
    P1120 - 35-00 - -
    Anyone know which bank of cylinders theese codes are reffering to?
    and better still which sensor?
    Beerzo's Avatar
    Masa'warty 3200... Talk To Me!
    Feb 2006
    Scotland
    1,241
    have you tried clearing them then going for a run then scan again. Could have been an old fault
    teambeer's Avatar
    Feb 2007
    Isle of man
    9
    Yeah tried that already and they re-appeared unfortunatly
    shineydave's Avatar
    Jan 2006
    Bradford, Yorkshire, UK
    912
    bank 1 is drivers side, plugs numbered 1 to 3 (front to rear
    bank 2 is passenger side, plugs numbered 4 to 6 (front to rear)
    B2 Lambda is a real pig to do, you definately need an O2 sensor socket to remove it, i did mine by cutting down a 22mm spanner but if you don't have a few kicking around that you can butcher you're fecked.
    once you've changed it and cleared the fault codes i'd guess the lean faults should go, that's assuming you're using decent fuel, i used to get all sorts of fuel trim readings before i knew better and changed to v-power
    Dave
    "If that's the Turbo Fairy knocking tell Her I'm not in"
    teambeer's Avatar
    Feb 2007
    Isle of man
    9
    Great thanks for that, geuss I'd better order one then, anywhere in particular worth ordering one from? Had a look on gsf but they don't list one for the AGB
    shineydave's Avatar
    Jan 2006
    912
    GSF do them, i got mine from there, about 50 quid if i recall about 6 months ago
    Dave
    Apr 2009
    35
    Did this fix your problem
    Scott 1998 Audi A4 B5 1.8 S E 5 Door Saloon
