Volks AutosChris Nott
    jcb
    Sep 2005
    uk
    4,077
    Crank - flywheel info needed
    Does anyone know (i.e. actually seen) the bolt pattern for RS4/S4 crank to flywheel compared to that of a 1.8t crank to flywheel?
    Is there any reason I couldn't use an RS4 clutch and (if needed) Flywheel on a 1.8t? both B5 chassis, both inline,
    I can;t think of one off hand but thought I would seek some advice.
    I want an uprated clutch with as close to OEM feel as posisble.
    RS4 is rated up to 400+lb/ft which is more than enough for me and will keep the dual mass OEM unit.
    any help would be great
    macca's Avatar
    Sep 2006
    Sussex.
    525
    i'm only guessing they are different as i thought ecs tuning say they modify the flywheel to take a s4 or rs4 clutch, is the s4/rs4 flywheel bigger diameter?
    i think rs4 clutch is the way to go though.
    looks like you and i have the same things planned for our cars at the moment.
    1998 A4 1.8T Sport - For Saturdays
    2003 VW Golf MKIV R32 - For Sundays
    2000 Peugeot 406 HDi - For when it's raining
    1996 Kawasaki ZX7R - For when I'm late for work!
    Mods- Forge Dump Valve, The Engine Shop Power Plus based Engine (Low Comp. Forged pistons, Arrow H-Section Rods, Newman fast road cams, polished & ported head), 19" wheels, B&M Short Shifter, Greddy Turbo Timer, RS4 Grill, Weitec GTN coilovers, HKS modified air filter, Autobahn88 FMIC, ChippedUK custom map. Some Turbo mods ongoing.
    jcb
    Sep 2005
    uk
    4,077
    that why I think an RS4 flywheel is the way forward, can't believe they would have a different bolt pattern between flywheels.
    can understand why an rs4/s4 clutch would fit on a 1.8t flywheel though.
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    I would think as the RS4 has a bigger engine the flywheel is likely to also be bigger and with more mass, if you fit a flywheel with larger mass onto a smaller engine, it wont run right, and will probably be more sliggish to accelerate.
    Just go for an uprated clutch to fit your existing flywheel, maybe a part ceramic one with an uprated pressure plate.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    PhilR's Avatar
    One Ate Tea
    Jan 2006
    UK
    330
    How much power are you aiming for ? my mate has a mk2 golf with an AGU 1.8t with IHI turbo running about 350 and he uses a standard clutch.
    Suppose it has less weight to propell though
    jcb
    Sep 2005
    uk
    4,077
    he is not 4wd either, only point of slip on 4wd is at the clutch.
    I haven't found a decent aftermarket clutch that isn't a stupid price or that requires a larger left leg transplant.
    Doc put me in touch with Southbend and they are around $600
    any thoughts on other options?
