AH FabricationsEM Tuning
Results 1 to 8 of 8
Thread: flashing code
    Feb 2007
    flashing code
    Hi There
    New to this site and also new to audi's(Excellent site i must say).
    The problem i have well not so much of a problem more curious than out else is on start up i get some beeps and a code i think saying " IN 2 " in the trip milage display.Obviously its there for a reason but do i need to be concerned about it.could it be related to my next question
    Its a 1996 1.9 TDI.
    Also can i ask if anybody knows if i can put the diesel injectors from a 110bhp car into the 90bhp car as one of mine has packed up the one with the wire coming out of it and is unrepairable the reason i ask is i can get the 110bhp ones very cheap off a friend will i have any problems in doing so and will i see an increase in performance.
    Many thanks in advance
    Jun 2003
    World of my own
    9,813
    The IN 2 warning is just to remind you you're due a service.
    In 1 is an inspection service
    In 2 is a major service
    Feb 2007
    Thanks Andymac for the quick reply is there any way to remove this code as i do my own services.
    shineydave's Avatar
    Jan 2006
    Bradford, Yorkshire, UK
    904
    you can prevent it appearing in the DIS by following the instructions i the owners manual, it's something to do with pulling out the left hand stalk that sits in the dash but i can't remember the exact sequence, search the forum, it'll be posted somewhere.
    this only prevents it appaearing AFAIK, to reset it completely you need to plug it into Vag-Com
    Dave
    "If that's the Turbo Fairy knocking tell Her I'm not in"
    Nov 2010
    Scarborough
    103
    The method shineydave mentions might not work on a 1996 car, didn't on mine.Only way you can reset them is with a full (ie bought) version of vagcom or visit a dealer or good independent garage.
    96 A4 Avant 1.8T sport
    Things to do:
    Sell it :-(
    1,877
    If your ever in the middlesbrough area I can rest for you.
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    577
    Yeah but hang on though. When was it last serviced?? It's never good practice just to clear it without actually doing something about it.
    As mentioned above, I doubt you'll clear the warning with the stalk method. Welcome by the way
    2000 1.8t quattro Sport totally standard (ish)
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,907
    the service indicator isnt causing the beeping though, something else is causing that, depending on how many it could be low screenwash, fuel, coolant etc.
    TD5 Land Rover Defender build
