Sky InsuranceVolks Autos
Results 1 to 13 of 13
    doeboy's Avatar
    Apr 2006
    Birmingham
    596
    Tyres rubbing @ full lock
    My 225/40/18's are rubbing, am i right in thinking that this is what wheel spacer are used for?
    Another issue is i'm due to have my RS4 reps repaired this week and i'm intending on changing the colour to charcol or some black shade, but thinking about it i don't think they can alter the colour of the centre cap can they? Being plastic it's hardly going to be able to "bake" at 200 DC now is it!
    Randomjim's Avatar
    Aug 2006
    Sussex, Uk
    2,747
    You must have the wrong offset wheel because i have 225/40/18 tyres and i've lowered my car 100mm and that doesn't rub.
    Built in Germany, Perfected in England
    Jan 2007
    51
    Thats good news because im really worried about lowering mine next weekend and the MOT is shortly after..
    But no rubbing on 100 mm you say im only going 30mm so should be safe then.
    doeboy's Avatar
    Apr 2006
    Birmingham
    596
    Right, so spacers should give me that little xtra width then?
    As i say it's only at full lock.
    Randomjim's Avatar
    Aug 2006
    Sussex, Uk
    2,747
    Yea maybe try 5mm spacers on the front that should do the trick.
    Randomjim's Avatar
    Aug 2006
    Sussex, Uk
    2,747
    Quote Originally Posted by rusty1983
    Yup you'll be fine.
    205man's Avatar
    May 2006
    worcestershire, uk
    1,014
    ive got 18X8 rs4s with a 35mm offset 225/40/18 tyres and dont have any problems with rubbing either
    alan
    PhilR's Avatar
    One Ate Tea
    Jan 2006
    UK
    330
    im lowered over a hundred mill, and only just catch on the inside on full lock thats with 18x8s with an et48, 15 mill spacers i have will sort that problem but will probs catch on the wheelarches then !!! If you aint rubbin you aint dubbin !
    Aug 2004
    Hertfordshire UK
    162
    depends what tyres you have, just had my front tyres changed from toyos to khumos and the front s rub a tiny bit now. Mind you the front is rather low. The Khumo tyres have much wider side walls to protect the wheels from kerbing.
    Formally a4 2.5 tdi (b5)
    Now Seat Ibiza tdi 130
    doeboy's Avatar
    Apr 2006
    Birmingham
    596
    Michelin Pilots sports.
    205man's Avatar
    May 2006
    worcestershire, uk
    1,014
    ive got pilot sports fitted on mine with no problems
    alan
    A4 2.4 30V PES Supercharged
    Sep 2006
    Derby
    159
    Quote Originally Posted by doeboy
    Have you had the front wheel alignment checked recently? if it's toeing out to far this can cause the inside edge to rub, on full lock, if its out a fair bit.
    A4 2.4 30V
    S6 avant
    Oct 2006
    bewdley Worcestershire
    689
    new 225/40/18 khumo's on mine with no clearance probs.
    2000 s6 avant, special order met, green, satnav, Bose, tv, solar roof, privacy glass, recaro silver nappa.
