even changing to other b5 1.8t clocks would require an immobiliser recode, Then the s4 is a v6 so the rev counter probably wouldnt work, not sure of the other differences on the s4 clocks apart from the badge, your b5 clocks would look quite nice with one of the small sport st0eering wheel badges stuck on
chop the pegs off double sided tape and bobs yer uncle
No they will not work as they would be calibrated for the S4, but (which is something I have not looked at) you may be able to swap over the facia dials if they look like they have the same rev & speed positions to A4's and swap that over.
i thought you could recode them with vag-com to reflect whatever engine you had in the car, might be wrong though. have a look on the ross tech website
