EM TuningJMB Retrofits
Results 1 to 8 of 8
    Rich's Avatar
    Rollin on boost mother hubbards
    Jan 2007
    Basingstoke
    373
    Good starting point for my mods?
    Hey hey, when I start getting some free cash again I'm going to start modding my A4 1.8T for fun and performance, dont really have much experience so I'll post my plan so far and if anyone has any comments or suggestions they would be more than welcome.
    1- Install Carbonio Air intake
    http://www.dpmautostyling.co.uk/cata...oducts_id=2771
    Hopefully this should up BHP 1-5 points but give a nice induction sound too - anyone got one/comments on this?
    2- Miltek exhaust with a high flow cat
    http://www.amdtechnik.com/product.de...eferenceID=371
    Again seen some good reviews of this, should optimise air flow and give a nice but not too loud and boy racer ish tone.
    3- Custom remap from AMD
    As seen here http://www.amdtechnik.com/product.de...ferenceID=7435
    Hopefully with the previous 2 stages done should be a good point to get this done.
    4- New brakes / coilovers
    After that I think it would be wise to install new brakes, unsure which yet though. I'd like to lower the car a bit but as I really like the ride quality at the moment as I understand it coilovers are the best option as oposed to lowering springs as they replace the whole system and will give a nice ride (hopefully).
    5- New intercooler, probably the forge one - unsure if I need this done as soon as I have the remapped engine to cool the extra power. If so I'll save up and get it all done at once
    6- Other bits like Diverter valves, probably get some new wheels and other external stuff.
    Thats it for now, any thoughts? Thanks for your help & advice
    PhilR's Avatar
    One Ate Tea
    Jan 2006
    UK
    330
    id work through that list, in a different order tbh.
    6. Diverter valves are usually knackered unless they have been replaced, the 710n (off the 225tt) is a good replacement if you plan on a remap, alternatively you have the option of the forge/bailey aftermarket valves.
    4 If i were you I'd want brakes and handling before more power
    1+2 Nice choices, i have a different carbon intake kit (Simota) on my 1.8t and it sounds nice.
    5 Intercooler before remap, otherwise you are increasing the capacity of the intake system after a custom remap. To answer your question a front mount intercooler is not really required for stage 1, remap
    3 Remap
    Sound like good plans though
    Rich's Avatar
    Jan 2007
    Basingstoke
    373
    Thanks that makes a lot more sense to do it in that order. How hard are the Diverter valves to fit? They seem relativly cheap so I'll probably replace that and get the carbon intake at the same time to start me off then think about brakes and intercooler. AMD will do the exhaust at the same place as the remap I belive so I can get them done together
    PhilR's Avatar
    One Ate Tea
    Jan 2006
    UK
    330
    Diverter valve is easy to do, you are best off taking the bottom cover off with the car up on ramps, its easier to access from underneath
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    Well I don't quite recon I would put a IC before map as you will not be running that much boost that it will really mater no unless you go K04-15 upwards with a very aggressive mapping then a IC would be advised. Has for intake not worth the money and I would only change it if you went for GT28RS+ as space become an issue.
    So I would go:
    Exhaust
    DV & Mapping
    Brakes (Big disc conversion with up rated pads will do)
    smitch's Avatar
    Sep 2006
    1,585
    Brakes definitely important.
    I've had my 1.8T chipped and when i went to see a mate on the Isle of Sheppey the other week i was coming down the bridge onto the isle doing 130mph and realised my standard brakes didn't actually work that well when i had to start slowing down a bit sharpish!
    Hadn't noticed before cos i never really drive on motorways and don't get the chance to use the top end speed.
    S4.
    Rich's Avatar
    Jan 2007
    Basingstoke
    373
    Thats cool, yeah I wont be running a stupidly aggressive remap just a standard one with the default turbo still. I think I may just save up some dosh and just get it all done at AMD at the same time for ease unless I can find a place locally that does Miltek exhausts or similar with high flow cat as that seems to be a significant limiting factor.
    Beerzo's Avatar
    Masa'warty 3200... Talk To Me!
    Feb 2006
    Scotland
    1,241
    tuning
    Quote Originally Posted by docurley
    So I would go:
    Exhaust
    DV & Mapping
    I am with this aswell.
    Exhuast - maybe go for a full decat system aswell, will let the turbo spool up a bit quicker.
    DV - will need to be done when or before the car is re-mapped.
    Brakes - Depends how daft your drive. ( I am looking into Subara WRX Sti brakes for mine )
    Suspension - Most tend to go for coilovers so they can get a ride quality that suits them. i.e. dampening level / height
