Monster MotorsportChris Nott
    audi ben's Avatar
    They call him the police version of the stig
    Aug 2006
    Worthing, Sussex
    37
    a couple of things!
    first of all thank you to the peaople about clearing the drainage section! it was clogged badly so all clear now and working fine!!!
    second I need to do an engine flush on the audi how easy is it????? and is there anything i should be aware of?
    third - i need some brake discs for my 2.8 v6 a4 B5 anyone know anywhere cheap?
    forth - trying to find some cheap floor mats for my one in charcol grey butbugger me no one does any! any ideas?
    and thirdly how much would a audi a4 2.8 se with 88k on the clock go for?
    jcb
    Sep 2005
    uk
    4,077
    2) coolany or oil? why do you want to flush. what milegae you on, you can open up a can of worms flushing older cars as you flush big chunks of crud off the walls and the have to stop somewhere, water pump, oil pump, oil cooler.....think DVT.
    As far as how easy it is, open appropriate cap, pour in flush, run engine, dump (responsibly!) refill.
    try persil on your coolant system for a good clean (not joking)
    3)four rings spares, VAG spares, choose a decent brand and shop around
    4) there is a custom mat company that was advertised in PVW or Audi driver or one of those mags, not silly prices either
    5)have a look on www.autotrader.co.uk
    Biglockie's Avatar
    Aye you know it makes sense
    Nov 2006
    cumbria
    1,030
    Persil??
    do ya just put it in then flush it??
    Seriously??
    Chris
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Having a city and guilds in motor vehicle repair, even though it was attained over 10 years ago, I would never put washing machine detergent in an engine.
    For a start it foams up and different chemicals have differing creep properties, so if you put in an alien fluid that has an advanced creep property then it may seep into somewhere it shouldn't be, like an oil gallery.
    And how do you think persil will react to coolant when you add it? I wouldn't like to guess.
    Try using a product designed for the purpose intended...
    Try that
    http://www.barsproducts.com/product.cfm?id=31
    or maybe try ariel...
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    audi ben's Avatar
    Aug 2006
    Worthing, Sussex
    37
    cheers peeps! the flush is because i have been doing too many short runs! it really needs it it has only done 89k
