JMB RetrofitsBadger5
Results 1 to 9 of 9
    Nov 2003
    Florida, USA
    9
    Resetting check engine light and ln1
    how did u reset the check engine light? also, right where the trip milage is, how do u reset the ln1 indicator?
    thanks
    Milton Keynes UK
    248
    Re: Resetting check engine light and ln1
    Hi,
    Below is copy of the instructions on how to reset the oil service light from a post in the Diesel section. It might be worth a try!
    Press and hold the right button. (odometer reset)
    now switch on the ignition
    (oil lamp will not flash, but on at all times)
    press the right button again
    (insp is now displayed)
    pull left button. (clock set)
    (------ are now displayed)
    Pull left button again
    This works on my A4 tdi (110bhp) but should work on all.
    As far as the 'Check Engine' light, you could try disconnecting the battery for 20 mins, this worked on my Impreza. Perhaps someone can confirm this before you try it, you might need to enter the code for the stereo after? Make sure you have your keys in your pocket before doing this incase the central locking activates!
    Otherwise, try a garage that has a diag tool or someone that has vag.com software and the diag cable.
    Hope this helps,
    Jim.
    Nov 2003
    Florida, USA
    9
    for some reason it doesn't work, i can't press in my left button, the clock button, i have a 97 A4.
    Nov 2003
    Atlanta, GA, U.S.
    23
    i had the same problem with mine. it should be in your owners man. You have to pull the left(clock) button out and then push the left button in. you might have had it backwards. but follow the inst. above.
    Oct 2007
    2,597
    Only works on cars built halfway through '97 and later, when it became mandatory, that the vehicle owner / operator MUST be able to re-set the service indicator, without having to visit a dealer, and without specialist software.
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Can you do anything else to reset the oil light VAG com etc?
    I have a R reg 1.8T
    A4 Avant project now started ! see this thread ! http://www.audi-sport.net/vb/a4-s4-forum-b5-chassis/43296-bit-project-going.html
    If you think my post had a usefull purpose please say thanks
    Oct 2007
    2,597
    Quote Originally Posted by Markey
    I have a R reg 1.8T
    On your car, you don't need VAG-com to reset the service / oil warning, just do it manually.
    jcb
    Sep 2005
    uk
    4,077
    it tells you in teh owners manual, but I followed teh instructions and still couldn;t get it to work!!
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Quote Originally Posted by Siena
    What as said above ?
    A4 Avant project now started ! see this thread ! http://www.audi-sport.net/vb/showthread.php?t=43296
