Sky InsuranceAH Fabrications
Results 1 to 14 of 14
Thread: s4 owning
    Jan 2007
    22
    s4 owning
    Thinking on getting one of these can any owners tell me what the bad points about owning one of these are?
    Also whats the best induction kit, exhaust and lowering springs to fit?
    whisky180's Avatar
    May 2006
    london
    79
    Quote Originally Posted by strapper
    fuel bill, forget air filters, get a re-map from mrc, decat exaust and miltek backbox, forget lowering springs get h&r arb's and coilovers. way to go
    noggy blue S4, hybrid turbo's, 470 bhp, and lots of bits, audi-sport. net sticker
    S6 avant
    Oct 2006
    bewdley Worcestershire
    689
    just hope one of the turbo's does'nt fail! ive heard its a very costly engine out job.
    2000 s6 avant, special order met, green, satnav, Bose, tv, solar roof, privacy glass, recaro silver nappa.
    Jan 2007
    22
    Do you have any pics of your car whisky180?
    Jul 2006
    1,562
    Yep, forget any thoughts of induction kits.
    MPG is poor if you do a lot of town/hard driving.
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,849
    Have you read the buyers guide at the top!
    whisky180's Avatar
    May 2006
    london
    79
    sure do, in the gallery
    Jan 2007
    22
    Why no induction kits?
    Al have a look in the gallery
    Jul 2006
    1,562
    Aside from sucking hot air in and clogging up far faster than a factory paper element, the filtration oils in them tend upset and kill the very sensitive Audi MAF sensors.
    GSB1's Avatar
    May 2006
    UK
    273
    Visit GSB1's Youtube Channel
    The intake isn't really a restriction.
    One 500+BHP S4 running a stock paper filter springs to mind as a good example.
    Even if you like the noise of induction, why risk heat soak or MAF failure?
    Present: Ice silver B8 S4 s-tronic saloon (standard)
    Past: Agate grey B5 S4 saloon (MRC tuned)
    Hers: Volcano red 8P A3 Sportback 2.0 TDI CR 170 sport quattro
    shineydave's Avatar
    Jan 2006
    Bradford, Yorkshire, UK
    912
    i've had mine 12 months now and i can't think of any bad points to ownership, there's plenty of stuff to check though before buying one.
    service history is a must, mileage wouldn't worry me as long as it's got a FULL service history. a VAG history is "alright" but specialist servicing such as MRC or Star performance is prefferable, mainly because the dealers don't see many of these cars and don't check them for fault codes as a matter of course. it's all to easy for a main agent to miss some of the common failures such as the throttle body boot or F pipe. most owners are knowledgable enough about their cars to service them themselves, if that's the case check that they own or have access to a Vag-Com, you can't look after one of these without one. some well chosen questions should be able to sort out the enthusiast from the dummy. i wouldn't discount buying a car that has been serviced at home as long as the points above could be proven.
    before buying insist on scanning the car with Vag-com. we negotiated a substantial discount just before xmas for a mate who bought one on the strength of a vag-com scan that showed a fault on the re-circ flap on the air-con and intermittent faults with the ABS system.
    brakes can be expensive so make sure there's plenty of meat on both pads and discs, if not then either insist on them being replaced before sale or again, negotiate a discount.
    check the tyre tread, and not just a quick glance, many S4's have been lowered but not had the camber adjusted accordingly which can scrub off the inside edge of the tyres so get undernieth and check the full width of the tread, whilst you're under there check the exhaust hanger behind the rear axle is still attached, these snap off, it's a common fault but an MOT failure.
    look for the highest spec you can, ideally you want to find a facelift car with sat-nav plus, recaros, carbon trim and a sun roof then haggle like a 5 bob hooker at last orders. facelift cars have slightly better brakes and the RS4 exhaust manifolds rather than the early S4 ones which tended to break up which was like sending an RSVP inviting the turbo fairy round to party.
    there should be no rust present whatsoever, these cars are galvanised from the factory and any rust is a sure sign of poor accident repair, walk away.
    there should be no oil leaks, especially from the back of the engine, this could be rocker cover gaskets (easy) or turbos or oil lines (a *****) so make sure you know what you're getting into and do the 5 bob hooker thing again, but this time it's 3 am and all the punters are getting taxis home.
    turbos. there's really no hard and fast rules on turbo failure. some fail early, some not at all, it all seems to depend on the way they're treated, if the car has been thrashed from cold or switched off after a fast drive without being allowed to cool then you almost guarantee the turbo fairy will be knocking on your door. same goes for running on crappy oil and make sure the after-run pump for the cooling system is working too. and don't forget the F-pipe and TBB as the turbo fairy LOVES boost leaks.
    remember, the turbo fairy is not our friend
    but if you buy wisely, service it with care and replace the known weak points you'll be buying the most fun you can have in a car short of inviting Lindsey Lohan for a naked moonlight drive accompanied by nothing but a family size tub of chocolate body paint
    Dave
    "If that's the Turbo Fairy knocking tell Her I'm not in"
    Jan 2007
    22
    WOW mate that read was educational as well as great help!
    shineydave's Avatar
    Jan 2006
    912
    i forgot to mention you should be looking for a car on 18"s so you can upgrade the brakes easily as the standard ones are just about ok until you go for the inevitable re-map.
    Dave
    Jul 2006
    1,562
    Spot-on shiney
