VF34 was standard on STI from 200 IIRC.
check out the following link
316 grade 1.5" OD Stainless tubing, I am also toying with the idea of larger tubing (around 1.75") but the smaller tubing will make it spool up lower down the range and I am not looking for nutty power. Just 350ish.... [
10mm laser cut 304 stainless flanges for head, turbo and exhaust.
Bends and pipes work will be about £80, welding I expect to be around £150 and the flanges were £100.
All in I hope to have it done for around £300-350
will look something like this:
That is a "Full Race" mani (robotically tig welded) retails at over $1000.
Not planning on the wastegate tube for the obvious reason
will let you know how I get on.
