i dont know the part number however i believe that pre facelift are not DBW (drive by wire). so its NOT a matter of taking out old then VAG.COM and tell it it has cruise control.
i think it may need a phyisical connection the the throttle body area may be??
The way to find out if you have DBW is to rev the engine to 2-3000 rpm in neutral. Hold your right foot steady then press the brake with your left. If the revs fall to idle then you have DBW. This is a safety feature to guard against the (electronic) throttle sticking open.
