Results 1 to 14 of 14
    Faulty's Avatar
    Dec 2006
    Scottish Borders
    46
    80w blubs. Risky or not?
    Well i decided to upgrade my existing blubs as i just wasnt feeling that there was enough light for my liking.
    My brother picked up a pack of Ring H7 80w Sportzblue at the local shop for me, but i know the legal limit is ment to be 55w(he didnt know that).
    What are the risks with fitting these blubs apart from the legal reason?
    205man's Avatar
    May 2006
    worcestershire, uk
    1,016
    i fitted 100w bulbs in my old calibra and they ended up melting/distorting the plastic on the back of the headlamps and had to replace both sides
    not saying would on your a4 but could be a possiblity
    also risk of wiring damage due to more current being drawn. although you may never see the full potential of the 80w bulbs due to the wiring used as standard, to get the most you would have to rewire with a heavier gauge to allow the full current they would need
    Jul 2005
    2,488
    yep, when i fitted 100W bulbs in my corrado I had to rewire them straight off the battery then use a relay to the headlight switch. Had no problems with melting the reflectors, and it went straight through MOT's
    All said though, using bulbs rated that high is still illegal.
    saying that, on my mk2 golf it was just sufficient to use an uprated loom with the old 55w bulbs.
    Jun 2003
    World of my own
    9,813
    "i fitted 100w bulbs in my old calibra and they ended up melting/distorting the plastic on the back of the headlamps and had to replace both sides"
    That's Vauxhall quality for you.
    BTW the existing wiring will not limit the current, what will limit the current is when the wiring acts like a fuse & burns out.
    S6 avant
    Oct 2006
    bewdley Worcestershire
    689
    ive got halfords superblue 80w bulbs in my 99' b5. theyve been in about 6mths now, i was a bit worried about melting stuff but they havent yet even when i did 220 miles at night back from cornwall. i think 100w are too much though without relays to feed them.
    Faulty's Avatar
    Dec 2006
    Scottish Borders
    46
    Good to know im not the only one that was worried!
    I went to fit them today and my only worry was when i switched them on with the bonnet still up i saw a small trace of smoke come from one light and a slight burnt smell. I could just be over paranoid but i just dont fancy my motor going up in flames one night!
    filipharvey's Avatar
    Amusing Tagline
    Aug 2006
    Fakenham, Norfolk
    518
    Talking of Calibra's, I had 130w bulbs in fogs and main beam and 100w for full beam and never had a problem with melting. Went through MOT ok too.
    Later on my Passat I had 100w sportzblues, and I didnt think the light output was any better than the standard 55w, due to the filtering effect of the blue colourant, hence why they are higher wattage in the first place, or so I was told. Saying that, it was a much cleaner light.
    Personally, after having both high wattage and blue bulbs, I would say it is better to go for a clear, high wattage bulb for best results. Failing that, check out ebay.com (US), as there are a lot of cheap HID conversion kits available there!
    Audi A6 1.8T Avant
    Alfa 156 3.0 V6 Veloce
    205man's Avatar
    May 2006
    worcestershire, uk
    1,016
    i replaced mine a couple of months ago and used halfords super brilliance bulbs, and eben though they are still 55w they are much better than standard and they were doing a special offer which i think is still on
    buy one get one free so you will only pay 20 for the pair not the 40 they should be (i wouldnt have bought them if they were 40........just me being tight)
    alan
    Faulty's Avatar
    Dec 2006
    Scottish Borders
    46
    I did see the halfords deal but i was more looking for blues with a blue tinge as ive just fitted blue sidelights. Just be difficult really!
    The HID kits look interesting and not too hard to fit so that could be an option.
    Jul 2006
    324
    have 100w main beam in my a4,the 1.5mm cable is well up to the current draw(less than 10 amps)
    Booth_S4's Avatar
    Riding on V8 power
    Oct 2006
    Newcastle, Staffs
    657
    i had 100w bulbs on my 206 ,as said that passed an MOT fine and i didnt seem to have any problem with melting plastic!
    German iz ze vay forvard!
    Made with vorspung durch tecnik
    2003 Noggy S4 Avant - 344bhp of pure V8 muscle
    S6 avant
    Oct 2006
    689
    just done a 400 mile round trip in the dark, with the 80w's in and they're fine -(i checked them after reading this thread and having them on for 3hrs at a time!!!)
    Faulty's Avatar
    Dec 2006
    Scottish Borders
    46
    Yeh i think i'm just alittle paranoid as my neigbour's car went up in flames last year and it was thought to have been an electrical fault.
    Ended up going with the Halfords super brilliance and theyre certainly better.
    Couldnt help myself while i was in there and picked up some indicator blubs for the front. Theyve got a blue look to them but light up orange, never seem them before but worth a try if get rid of the fried egg look!
    JohnnyRob's Avatar
    Dec 2006
    Sunny West Surrey
    76
    I fitted over power blue bulbs to the wifes 4x4. They did look good and gave a nice light, however, two problems spring to mind; firstly other drivers did, on occasion, flash her - I assume the light 'dazzled' them, and secondly both bulbs blew (at the same time!) after only 12 months use. The car has no other modifications or extra lights and is now fitted with factory spec bulbs.
    I wouldn't bother - just buy decent branded (ie philips hyper) bulbs.
