Chris NottVolks Autos
    rusraf's Avatar
    Nov 2006
    northampton
    39
    a4 quattro poor starting
    hi..i have a 1998 a4 2.8 quattro..it starts first time,but with a little blue smoke for about 15 seconds then clears..juswondered if this was a problem..maybe just burning of a little oil.??
    russ
    rusraf's Avatar
    Nov 2006
    northampton
    39
    this only ever happens first thing in the morning...like a little oil has got into the engine
    Phantom_A4's Avatar
    Jan 2006
    Southwater, United Kingdom
    562
    Probably where it's been sitting over night, would suggest a small oil leak in the engine somewhere. Wouldn't say it's a major problem as most cars do it, would get it checked out just incase there are any other problems with the engine
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    Valve stem oil seals?
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    rusraf's Avatar
    Nov 2006
    northampton
    39
    is this something to worry bout..valve stems...as theres 30 of em.!!! or is it just normal..engine done 120,000 miles..drives good...
