Chris NottMonster Motorsport
Thread: steering wheels
    Oct 2006
    32
    steering wheels
    ok , i have two steering wheels the same , one is complete and on car but has a rip in it the other has the front and airbag missing ,
    so!
    can the airbag be removed from one to the other , if so what how hard and what else would it intail
    thanks phil
    Nov 2004
    Kent, UK
    138
    Phil,
    If they are the same steering wheel model then yes they can be swapped over.
    There will probably be two torx bolts on the back of the steering wheel that need to be undone to withdraw the airbag and it's front.
    Withdraw the airbag and undo the connections.
    Undo the big nut holding the wheel on. On later cars this was a large spline drive nut.
    Swap the wheel and refit air bag.
    Remember that if you turn the steering to get at the two torx bolts to make sure it is straight again before taking the steering wheel off so that the new wheel goes on in the same place.
    John
    B5 S4 avant - for sale!
    Allroad 2.7T
    Oct 2006
    32
    Quote Originally Posted by QuantumJohn
    Phil,
    John
    whats torx bolts ?
    would the airbag need resetting ?
    thanks phil
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    Bridgend, South Wales
    617
    Torx are a type of splined-head fasteners, which to undo you need the relevant size of Torx bit......
    Have recently done a steering wheel swap on my own car, following advice from folks on here and of course a thorough reading of the Haynes manual relevant section.....had no problems at all.
    Changing steering wheel, anybody here done it?
    '99 Ming Blue A4 Avant TDi SE 110 + Dragon Performance Tuning Box
    Factory sunroof / Cruise / Aircon + Climate / Royale Blue leather
    '72 1302LS Karmann Beetle Cabrio Silbermetallic
    '63 Karmann Ghia Sunroof Coupe Pacific Blue
