Badger5Sky Insurance
Thread: fuelling mods
    a4quat's Avatar
    Aug 2006
    middlesbrough
    366
    fuelling mods
    would i need to remap after fitting this
    http://www.atpturbo.com/Merchant2/me...ory_Code=VVWFE
    or this
    cheers!!!!!!
    a4 1.8t sport quattro
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    Definatly after the injectors, the rail is mostly to look pretty and enable external adjustment isnt it?
    dummi's Avatar
    smoking a6
    Mar 2004
    brumingham
    1,188
    i don't think your stock injectors are far off that. without a turbo upgrade you wont gain much. and yes your fueling parameters will change with higher flow injectors. you will be running rich unless the difference is so small the computer would compensate. these injectors are mainly for converting a NA car to forced induction.
    my thoughts are on the fuel rail upgrade at the most you may lose out top end in more extreme setup unless you would upgrade fuel pump too. and unecessary unless you are doing a big turbo.
    just a little a6
    a4quat's Avatar
    Aug 2006
    middlesbrough
    366
    so basically, big injectors are a waste of time unless i upgrade the turbo!
