    Sep 2006
    Paisley
    Question Amber rear lights
    Hi All,
    I've just joined the forum, and this is my first post.
    I recently bought a 96 A4 1.8T Sport. Great car but the one thing that dates it is the amber rear lights. I have sourced a pair of red lights from the 97/98 model, but the bulb holders are different. Is it just a matter of fitting the bulb holders from a 97 model to get them to work?
    Thanks,
    Barry
    Beerzo's Avatar
    Masa'warty 3200... Talk To Me!
    Feb 2006
    Scotland
    1,241
    I would assume so. Do you know any one else that has an A4 with the newer style lights then you could test try it using their bulb holders? Even try a local scrappy.
    What does the socket that plugs into the bulb holder look like? I could check the shape of them against my car to see if they are the same. That would only garauntee that they would fit into the socket not how they would light up.
    What is the current set up for the lights in terms of what lights up and where? I am sure there are 4 sections all may not be used though. What does the top section light up as, down to the bottom?
    I.E.
    TOP --> Tail light
    MIDDLE TOP --> Fog light
    MIDDLE BOTTOM --> Indicator, Reverse light
    BOTTOM -->Tail light
    Any boys on here around the same area as mcleodbz that could let him try their bulb holders.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,505
    I am 90% if you went for 1996 to 98 lights as long as you have the holders it will be fine, if you get the 99 to 01 lights, you will need to swap 2 wires around on each connector
    Sep 2006
    Paisley
    Thanks guys - I think the 96/98 bulb holders will be fine. I will try and get a set of bulb holders from a scrappy to see.
    I think the light layout is:
    Top - indicator
    Middle - brake
    Middle bottom - tail
    Bottom - reverse light/fog
    Feb 2005
    Isle Of Lewis, NW Scotland, UK
    197
    I did this to my old A4, which was a 1996 N plate. I sourced all red lamps from a 1997 P plate, and together with the bulb holders, it was a straight swap. Makes the car look a couple of years younger too.
    My Fleet:
    B7 Audi A4 3.0 TDi 233 S-line Quattro
    B5 Audi A4 1.9 TDi 110 Quattro
    B5 Audi A4 1.9 TDi 110 SE
    B3 Audi 80 2.0 8v Sport
