Badger5AH Fabrications
Results 1 to 11 of 11
Thread: Annoying Beeps
    filipharvey's Avatar
    Amusing Tagline
    Aug 2006
    Fakenham, Norfolk
    518
    Unhappy Annoying Beeps
    Just recently, whenever you turn the key to start the A4, it beeps, like a heart monitor. There are no visual warnings as such (apart from saying it needs an oil service, but the OIL has been flashing longer than this beep thing has been going on!), and it is fairly intermittent.
    Doesnt seem to affect the running of the car, just a lil bit annoying!
    Any ideas what it may be?
    Audi A6 1.8T Avant
    Alfa 156 3.0 V6 Veloce
    tubtub's Avatar
    Jul 2005
    SW England
    160
    I seem to recall there's a warning beep(s) if the battery charge drops to a low level.
    there's nothing like the smell of diesel before breakfast...
    Jun 2003
    World of my own
    9,813
    Might be the alarm, I know the A3 suffered from 3 or 4 beeps when the backup battery in the alarm module starts failing. This was also accompanied by the alarm going off randomly in the middle of the night. Haven't heard that the A4 suffered from this though.
    Aug 2004
    Hertfordshire UK
    162
    mine does this but only when it needs something doing, ie fuel, washer bottle low or bulb gone etc.. always comes up with a light, reset via vagcom and see what happens
    Formally a4 2.5 tdi (b5)
    Now Seat Ibiza tdi 130
    Amusing Tagline
    Aug 2006
    Fakenham, Norfolk
    518
    No warning lights! Also no VAG-COM! If anyone in the area (Fakenham, nearish to Norwich) has one I could use I would much appreciate it! (need the oil service light resetting anyway!
    Still beeping though!
    Audi A6 1.8T Avant
    Aug 2004
    Hertfordshire UK
    162
    dont know if yours is different but i can reset the oil light by pulling one stalk out, turning on ignition then pressing the 2nd stalk.
    Jun 2004
    Northants
    126
    Think it's the alarm,
    My A4 has exactly the same problem. Only tends to happen though when i haven't used the car for a day or two. Think a new siren is required but they're not cheap. I'd be tempted to live with it for now. :-)
    Amusing Tagline
    Aug 2006
    Fakenham, Norfolk
    518
    Bugger! Can I just pull the alarm fuse then dya reckon?
    Audi A6 1.8T Avant
    Jun 2004
    Northants
    126
    Talking
    Don't think it's as easy as that.
    Might be better having an aftermarket alarm fitted that makes a decent noise when it is set off.
    Think most alarm specialists will disable/remove the factory fit alarm.
    I'm just going to live with mine until it stops working.
    simonwjones's Avatar
    Aug 2005
    staffs uk
    351
    You can just unplug the alarm horn and the system will still operate, dorrs lock, hazards flash when the alarm goes off.
    Been there, got the tee shirt
    Mines an A6 but I would suspect that its the same anyway. Seeing as the horns are so quiet anyway whats the difference.
    Simon
    Amusing Tagline
    Aug 2006
    Fakenham, Norfolk
    518
    Quote Originally Posted by kris_tdi
    Not on mine! One of them is for the clock!
    As for the beeping, just to clarify, it is from the dash, not a horn, my alarm works fine!
    Audi A6 1.8T Avant
