AH FabricationsChris Nott
Results 1 to 15 of 15
    doeboy's Avatar
    Apr 2006
    Birmingham
    596
    Won't flippin start!
    My 2.8 (1998) Won't start, it's been unused for one day i tried to start her this morning but she won't have it. It's happend 2/3 times in the past 5 months but started after a 2 or 3 seconds. Now it won't start at all. Surely this isn't simply a spark plug failing? The battery is only 8 months old or so. Other than those 3 times when she's struggled i've had no indication of any problems? It was raining all day yesterday. is dampness an issue? What are the most common causes?
    I also have no warning lights showing.
    Jun 2003
    World of my own
    9,813
    Is she turning over but not firing?
    Is she not turning over i.e. completely dead?
    Is she starting then dying?
    Is she firing a bit but failing to start?
    doeboy's Avatar
    Apr 2006
    Birmingham
    596
    she's turning over but not firing, she's tried and almost caught once or twice then she just turns only.
    Space Invaders Champion
    Aug 2006
    65
    My 98 2.8 also has starting hang-ups. In the last 3 months the following scenario has occured about 5 times.
    Turn engine over, it fires up then dies. It does this anything upto 10 times and then miraculously sires up and runs perfectly. It then starts on the button with no problems for weeks.
    Then, randomnly, it happens again.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,355
    is the little key on the dash flashing?
    doeboy's Avatar
    Apr 2006
    Birmingham
    596
    Quote Originally Posted by johnie72
    My mechanic said try it 10 times, something to do with some form of reset. Hasn't worked for me.
    As for a key flashing on the dash, nothing out of the ordinary is showing.
    marmite's Avatar
    Counting the Tesco Club points
    Jul 2006
    Barnet
    1,070
    Quote Originally Posted by mawhitey
    Sounds like Immo fault m8 very quick and easy to see!
    Good way to test is put the key in the ignition and turn it on but don't start it, wait to see if the Immo light goes out(little yellow key) if it dose try and start if it flashes then that is were the problem is.
    Ok, if the light is flashing have you got another key to try..maybe a key fault?
    If not try moving the steering column up and down, might be th reader coil wire and in moving the coulmn about can move the wire...I helped Tracer with this fault a while ago..search the threads about it..
    If not you may have a coolant temp sender fault, test with VAG-COM
    good luck and let us know
    Audi RS6 Daytona GreyLoving all 455.7BHP of her
    Jun 2003
    World of my own
    9,813
    Most likely the reader coil as this is a common fault on the B5 A4. My 2.8Q had a spate of this last year then just as I was getting the info on here on how to fix it it hasn't done it since. It's not a faulty reader coil just an intermittant break in the wiring, probably caused by the steering wheel adjustment being used a lot over time. Do you share the car with your other half? i.e. constantly readjusting the steering wheel height.
    As to Doeboy's problem could be any number of things.
    Electrical, fuel, cold start sensor.
    Definately not battery/alternator/immobiliser/starter motor.
    Cold start sensor would be my bet, this should show up as a fault on VAGCOM.
    Try using Optimax (or whatever it's called these days). My A4 doesn't like supermarket fuel at all - starting probs, running hesitancy etc.
    Also won't start reliably if the fuel is low (less than quarter full). I think the fuel pump is a bit shagged and needs the extra gravitational uumph of a full tank.
    macattax's Avatar
    Oct 2006
    Ireland
    451
    Did you check the oil level was ok?
    Jun 2003
    World of my own
    9,813
    and your tyre pressures!
    doeboy's Avatar
    Apr 2006
    Birmingham
    596
    My oils fine and all my tyres are flat
    I use only premium fuel (incidently, i only use Shell V fuel now, 99 octane its much better than 97 you can really real the responsiveness and i swear it's go faster effects are genuine too. )
    I did adjust the steering column on the day this happened.
    So for we've found that the car was standing still on a rainy day the whole day, which doesn't happen often, and i moved the steering column either the day before or the day before that.
    I've just checked she almost starts...almost! key on dash goes off as normal. Moved steering column a few times and still same problem. I'll just leave it to my mechanic on monday.
    Jun 2003
    World of my own
    9,813
    Yes it won't be the steering column as this relates to the immobiliser issue, where the car starts then dies immediately.
    DIPS_A4's Avatar
    SEAT LEON CUPRA R (225)
    Mar 2006
    Leicester
    566
    Thats exactly the same problem to what happends to my bros skoda octavia vrs its getting booked into the local skoda garage for next week. see what the faults are. its been at skoda for 3 weeks now due to them being busy.
    filipharvey's Avatar
    Amusing Tagline
    Aug 2006
    Fakenham, Norfolk
    518
    Quote Originally Posted by macattax
    Was then going to say that!!!
    I had this problem and that was the cause!
    Obviously not in this case tho!
    Audi A6 1.8T Avant
    Alfa 156 3.0 V6 Veloce
    doeboy's Avatar
    Apr 2006
    Birmingham
    596
    Solved at the cost for 30 for my mechanic's time. Something in the fuel! Seriously odd though. He took the fuel cap off and gave me a sniff, smelt faintly of chip fat. He took a sample and there's a white residue that sinks to the bottom. Somehow it had clogged and stopped fuel passing to the engine.
    Whatever it is, it's either got into the tank via the previous owner or via the petrol pumps. Perhaps some idiot tanker driver stuck diesel in the reservoir at the garage, which was then flushed. Who knows!
