Replacement Rear Top Mounts
Phantom_A4
Southwater, United Kingdom
Hi guys, just a quickie.
Does anyone know of any make of 'uprated' top mounts, as mine have begun to start knocking......need a new set, so better get some stronger ones than normal, as the suspension is under a lot more pressure than usual.
Thankies!!
They look like for a VW Beetle A4 type chassis, like we have the B5 type.
I am gonna see if there is a washer/shim i can add tomorrow,
Will keep you posted
Mawhitey - it says they are for the 1.8l too, which you can only get in 2wd form, so as they are aftermarket they might look different???
Raymie - I'm really thinking of it, all my friend have told me to keep it, as i wouldn't be the same without it. Also the rest of the parts i ordered turned up a few days ago, which i totally forgot about, so seriously thinking about it. If not the rears are slightly knocking so i must get that sorted before, if she goes. :)
555
jbh
17
4K
Nez
914
